PUK Code
PUK stands for Personal Unblocking Key. This is a unique eight-digit code specific to your SIM card. This is required when the PIN number to unlock your mobile phone is entered incorrectly 3 times. You are then given 10 attempts to enter your PUK code. If an incorrect PUK code is entered after the 10th attempt, you will block your SIM card permanently and will require a new SIM card from your mobile phone provider.
PUK codes can be obtained through the following ways - The PUK code is in your SIM card documentation Starter Pack. If you do not have this then - Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give them your account details and they have confirmed your identity. For details to obtain the PUK code for the SIM card, please click on this link and follow my instructions.
http://www.fixya.com/support/r5705889-puk_code
SOURCE: know if my lumia 800 is locked or not
If you look at the IMEI/Barcode label on the Lumia's box it should tell you what version it is, probably in the right corner.
If it says "UK CV" or similar then it's unlocked, if it mentions a network like Orange, three etc then it's probably locked.
Also if the phone has a networks logo on the screen during boot up this is also a sign that it could be locked.
Try using a SIM card from a different network.If you can, it's unlocked.
Hi
PUK code is called as PERSONNAL UNBLOCKING KEY.
Your phone will ask for PUK code when you entered the PIN code wrongly several times depending upon the mobile make. The mobile asks for PUK code so that unauthorized persons do not use your mobile for wrong cause.
To get PUK code please contact your service provider through phone or go directly to their office. They will provide you the PUK code for your mobile. The PUK code for mobile phone.so that you can open your phone. When you planning to call your service provider you cannot use your mobile as it is fully locked. Please use some other mobile with same network to call your service provider.
While you get the PUK code ,the service provider customer care officer will ask for your personal details to check whether the mobile belongs to you only. If they are satisfied with your answers they will provide with the PUK code
DONOT enter the PUK code several times wrongly,It will block your sim card permanently.
This PUK code is FREE. You no need to pay any sum to get the PUK code
Thank You.
SOURCE: Where can I find a manual for Nokia Lumia 800 in English?
You may view the online manual and/or download the PDF manual from here.
Try calling either #228 or i think its *228 and re-programming your phone, it will change the lock code to its default, he last 4 digits of your number without changing anything else
