Question about KitchenAid KCMS145J Microwave Oven
Error message of 8.3.4 on KitchenAid Microwave KCMS145J 1100 Watts Microwave Oven
A 8.3.4 error message is showing on my KitchenAid Microwave KCMS145J 1100 Watts Microwave Oven. When the door is opened, there is not light. The light will come on after the door is left ajar for a few seconds and when you close the door it will run for a few minutes and then shut off. Cannot program anything using the program pad.
SOURCE:
MicrowaveSvc
  • 9174 Answers
SOURCE: Stopped heating food
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here onFixYa:.
You can find helpful exploded view diagrams and order parts for many brands by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you may be able to download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Jan 01, 2009
  • 574 Answers
SOURCE: Kitchenaid KCMS185JSS-3 microwave - no power
Well your gonna have to take it down a take apart the microwave more than likely. Probably have a shorted HV diode,magnetron, shorted winding in HV transformer.burnt or frayed HV wire insulation
Posted on Sep 03, 2009
SOURCE: KitchenAid KCMS145J Microwave Door Latch Broke
I downloaded a parts schematic of the door latch assembly and thought I would determine the broken part, order a replacement and install same. As soon as I started to remove the shell of the unit to get at the latch assembly, I discovered non-standard fasteners are used. My wife advised me to stop and take it to a service center because she did not want me to mess up the containment of the radiation! Thanks for your interest. MB
Posted on Sep 08, 2009
MicrowaveSvc
  • 9174 Answers
SOURCE: my kitchenaid microwave/convection oven shows "DOOR" on display
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Sep 20, 2009
MicrowaveSvc
  • 9174 Answers
SOURCE: microwave oven door heavy
If one of your door springs has failed, you will need to replace both, as well as any associated hardware that has failed.
You can find links to helpful exploded view diagrams and part ordering help here.
Posted on Nov 29, 2009
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
KitchenAid KHMS155LSS when press "bake potato" button,start flashing error F3
Question: Error Code - Oven - F3 Error Code - F3 E0 Answer Product Symptom:
Error Code/Message - Oven - F3 Error Code - F3 E0
Control displaying F3 E0:
There may be a problem with the Oven Temperature Sensor, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Jul 31, 2014 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Kitchenaid microwave runs for a few seconds and then shows error code F7. Kitchenaid Phone Center never heard of this error.
Hi alykat737,
This error code F7 on KitchenAid microwave is about a function key that is stuck on ERC. You will have to Replace control board (also called ERC or clock) to fix the problem. In case you will have to buy a replacement part you may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Feb 06, 2011 | KitchenAid KHMS2050S 1200 Watts Microwave...
Error code F2
The error code "F2" that appears on your KitchenAid microwave refers to a keyboard failure/short on the front button panel or loose keypad connector
Attempt the following to clear error:
Check keypad connector for firm connection.
Press "Cancel" after the error code is noted, if error code returns after 60 seconds, replace keypad ( also called touch pad or membrane switch ).
Best of Luck with the microwave.
Jan 26, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Error F7
Microwave will not operate (cook). F7 error code
appears on the display.
Electrical circuit interruption between L1 and Neutral in
the microwave inverter circuit.
Possible reasons:
1. Check door, hinge and cavity front alignment and adjust
as needed.
2. Check the operation of all interlock switches.
3. Check over temperature protector for the magnatron.
4. Check all Cavity Thermostats for closed circuit.
5. Unplug the oven for at least 40 seconds. If this solves
the problem
A. Check the Cooling Fan for proper operation or
blockage
B. Check the resistance of the magnetron thermostat.
It should be 0 Ohms, replace if necessary.
6. Check that the control cable to the 1100 watt inverter
is properly connected to plug P2 on the display PCB
& Adjust or Reconnect
7. If interlock switches operate correctly, replace 1100W
inverter.
8. If problem persists, replace control assembly.
Nov 18, 2009 | Whirlpool GH9176XMS 1100 Watts Microwave...
My GE microwave, model #WES1450DM1BB; serial #SM908139U, shows
When I try and heat some food, the microwave runs but doesn't heat anything, its a model wes1450dm1bb
Mar 15, 2009 | GE XL1800 1100 Watts Microwave Oven
Kitchenaid built in Microwave model YKHMS155LSS-0 Starts by itself, displays PAN, beeps intermittently and sometimes displays an F1 error
Dougmcduff have you resolved this problem with you kitchenaid microwave turning on periodically??? I have the exact same problem. Any solutions? I called Kitchaide and no help there.
Mar 10, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I have the same latch problem that you really thoroughly described the problem and resources back in 2006.  It was in KCMS145J 1100 Watts Microwave Oven >Troubleshooting My problem is that I have removed...
I wouldn't trust the super glue, especially if it's a nylon part.
I would use epoxy, but you may not have enough room to slather it on without getting it in the pivot hole, etc.
A new latch (release lever) may very well be needed.
Good luck.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 10, 2008 | KitchenAid KCMS145J Microwave Oven
KitchenAid KCMS145J Microwave Oven Logo
46 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jaime Hernandez
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
