Do you mean the network unlock code?I was not able to get a free unlocking service for the mobile model that you have specified.You can get the unlock code for your Blackberry Curve 9320 from unBBlock.com and remove the network lock easily.
SOURCE: Unlock code for blackberry curve 8330
As long as you have the Sprint 8330 Curve and not the new 8350 model, you should not have to do anything. Most CDMA phones don't need to be "unlocked". The blackberry curve also doesn't have a lot of branding either so worse case scenario after you switch to Verizon you can download the latest operating system version and install it and you should be good to go. You just can't take a 8330 to a GSM carrier like AT&T or T-mobile.
SOURCE: i need unlock code for my blackberry 8520 curve
How To Unlock a Blackberry Curve 8520
1. Turn on your Blackberry Curve 8520 phone with your current network/service provider’s SIM card.
2. Using the menu go to Settings Menu -> SIM card and press select.
3. While holding the SHIFT key, type mepd.
4. You should now see the five locking categories listed.
5. While holding the SHIFT KEY, type mep2.
6. Release the shift key.
7. You will now be prompted to enter the Network MEP code.
8. Enter the Unlock Code.
9. Enter Return/Enter.
10. Your Blackberry Curve 8520 phone should then be unlocked.
Now you should have yourself a fully unlocked Blackberry Curve 8520. Before you can use your newly unlocked phone on a new phone carrier’s network, you must buy a SIM card and order a voice plan with that carrier. If the steps above did not work on your Blackberry Curve 8520, do not try repeating as this could just permanently lock your mobile phone.
SOURCE: i need an unlocking code for blackberry curve 8520
Well if you are tied to a particular network all you have to do is call up the customer help line of the service provider and ask them for the unlocking code, which will be provided to you for a nominal amount of money.
You can also get the unlock code through online..........i will suggest the website http://www.blackberryunlockingcodes.com which is doing good service .....you can approach this website.
SOURCE: need free mep code for blackberry curve?
It's a clear and fully detailed guide on how to unlock a BlackBerry Curve :
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keyboard (if your BlackBerry have touchscreen)
7. Type MEPD ( you will not be able to see what you are typing )
8. Type MEP2 or MEP4 ( you will not be able to see what you are typing )
9. Now the phone will prompt you to enter the mep code
10. if you not already have the code, then i suggest BlackBerryMEP.COM to get it from .
11. Enter the mep code ( you should see "code accepted" )
12. Restart your BlackBerry .
All done.
SOURCE : BLACKBERRYMEP.COM
