Question about Motorola MJ270R Talkabout 2-Way Radios with 27-Mile Range
Motorola mj270r no range
I recently bought these and have them set up on same channels and frequencys. i can not get no range from these things fully charged walk out the door leave for work which by birds flight 1-1.5 miles from my house. there are some trees but nothing thick no hills that would block signal i am aware of these possibilites of being the probem. these radios i have just have no range and are supposed to have UP TO 27. i know ill never get that but they can do way better than they are now. is there a certain channel and freq that will help boost range or some kind of trick to these ??? how can i get better range than >1 mile girlfriend couldnt even hear me it was just static.
  • Motorola Master
  • 1,655 Answers
Handheld radios talking line-of-sight with no obstacles will communicate approx. 2 miles. When talking from inside a building to outside, you can expect 1/4 to 1/2 miles range. Holding the antenna perpendicular to the ground gives you the best range. Height and placement of the antenna determines range. If you were on a mountain you could talk many miles into the valley below. However, in real world applications, range is limited. It can even be limited by the body fluid of the person wearing the radio on their hip, or blocked somewhat by the metal of the automobile one is riding in.
Channels 18-22 are listed as GMRS channels and may have more power than 1-17. The FRS channels are limited to 1/2 watt. But don't be fooled wattage doesn't equal distance. Higher wattage may give you a little more distance, but mostly it will give you clarity in the fringe areas.
Here is a link to the user guide: http://www.motorola.com/web/Business/Products/ConsumerTwo-WayRadios/Talkabout-MJ270R-Two-Way-Radio/_Documents/MJ270.pdf
A link to Motorola's page about the radio: http://www.motorola.com/Business/US-EN/Business+Product+and+Services/Two-Way+Radios+-+Consumers/MJ270R_Talkabout_Two-Way-Radio_B2B_US-EN
And I see where they are quoting 27 miles*, and go on to say:
*How far can I expect my radios to communicate? The communication range quoted is calculated under optimum conditions, with an unobstructed line of sight. Actual range will vary depending on terrain and conditions, and is often less than the maximum possible. Your actual range will be limited by several factors including, but not limited to, terrain, weather conditions, electromagnetic interference and obstructions.
Unfortunately, we are seldom in idea conditions. Radio-to-radio is going to get you 1/4 mile to 2 miles in real conditions.
Best regards.
Posted on Feb 25, 2013
SOURCE:
Benimur
  • 6966 Answers
SOURCE: AXU4100 Manual or help
On a Motorola AXU Series (including the 4100):
1. To unlock, press the “D” button for about a second or until the circle is gone. The circle with the line thru is the keyboard lock indicator;
2. To change channel, you need to press either the arrow left or right in Normal Mode;
3. To change PL (assigned to a channel), don’t think this can be done by the user
4. To change Ch. 1 from 464.500 MHz (PL-67.0) to 463.525 (PL-136.5), don’t think this can also be done by the user.
Even the built-in Programming Mode Parameters do not have this option to change assigned frequencies and PLs. An external programming software using a PC may or may not allow this.
These radios came pre-loaded with its channels assigned with specific frequencies/PLs. As used in a Motorola AXU411, they are:
Channel Frequency PL
1 464.500 67.0
2 464.500 77.0
3 464.500 88.5
4 464.500 179.9
5 464.500 None
6 464.550 67.0
7 464.550 82.5
8 464.550 94.8
9 464.550 179.9
10 464.550 None
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Dec 24, 2007
eradiostore
  • 1655 Answers
SOURCE: change scanning feature for different channels
When having the radio programmed indicate to the programmer which channels you would like to have in a specific scan group. They an at that time set up a particular group for you.
Posted on Jun 26, 2008
eradiostore
  • 1655 Answers
SOURCE: Motorola T5728 walkie talkie freq mismatch
Unfortunately the T5728 is not compatible with the US FRS (family radio service) frequencies. The T5728 operates between 409-410MHz. The FRS radios operate between 460-470 MHz. FRS frequencies are license-free frequencies for use in the US, as regulated by the FCC. Other countries have differing rules and thus their frequencies assigned to family usage differ.
Posted on Apr 09, 2009
Neto
  • 123 Answers
SOURCE: Require Frequencies for CTCSS codes for Motorola GP 2000
check this link at page 21 or see below
CTCSS PRIVACY CODES FREQUENCY CHART (Hz) Code Freq. Code Freq. Code Freq. Code Freq. Code Freq. 1 67.0 9 91.5 17 118.8 25 156.7 33 210.7 2 71.9 10 94.8 18 123.0 26 162.2 34 218.1 3 74.4 11 97.4 19 127.3 27 167.9 35 225.7 4 77.0 12 100.0 20 131.8 28 173.8 36 233.6 5 79.7 13 103.5 21 136.5 29 179.9 37 241.8 6 82.5 14 107.2 22 141.3 30 186.2 38 250.3 7 85.4 15 110.9 23 146.2 31 192.8 8 88.5 16 114.8 24 151.4 32 203.5 * Channel 8,9 and 10 are designated Canadian Marine Frequencies * Channels 8~14 are low-power FRS license free channels Note: Privacy codes can be programmed for use on Channels 1~22 only
Posted on Feb 04, 2010
Testimonial: "Thanks for the response. appreciated it. It is very useful."
SOURCE: XU2100 (1 Channel) 2-Way Radio: How do I change frequency on a motorola xu2100...
Hello, I just purchased 3 of the discontinued XU2100 radio's, Can someone help me to change the frequency on them? My email address is cubnboy@yahoo.com. Thank u for your time...
Posted on Feb 22, 2011
Motorola MT352R can transmit but cannot hear
Check your Code setting. Both the frequency and the code must be identical for the units to communicate. Shut off any special features and keep the radios at a simple setting until you get communications back.
Mar 26, 2014 | Motorola MJ270R Two Way Radio
HOW TO SNYC MOTOROLA CLS1110 TO MJ270R
Sorry, these two radio have no common frequencies.
Feb 11, 2014 | Motorola CLS 1110 (1 Channel) 2-Way Radio
MJ270R
Typically this would indicate a battery problem. Try swapping batteries with a known good unit. If the radio still shuts off when the PTT is pressed you have a radio problem. If it works fine, then you know your battery, despite showing fully charged, is bad.
Best regards.
Oct 24, 2012 | Motorola MJ270R Talkabout 2-Way Radios...
I have a new T5728 talkabout. My friends have T5720. When I bought my T5728, I thought that it would connect to any motorola talkabouts, assuming that we are on the same channel.. However, I was...
Unfortunately the T5728 is not compatible with the US FRS (family radio service) frequencies. The T5728 operates between 409-410MHz. The FRS radios operate between 460-470 MHz. FRS frequencies are license-free frequencies for use in the US, as regulated by the FCC. Other countries have differing rules and thus their frequencies assigned to family usage differ. Best regards, and sorry we could not help.
Dec 15, 2010 | Motorola Talkabout T5720 (7 Channels)...
I have a Motorola Axu4100 , I want to change the frequence that I currently have on this radio to a Motorola CP-200...just wondeing if these two radio can work together....
Hi
Motorola CP-200 have frequency range
VHF: 136–162, 146–174MHz;
UHF: 403–440, 438–470, 465–495MHz depending on the model
Motorola AXU4100 have frequency range 435 - 480 Mhz
The first model has a wider frequency range so it is best to include transmitter Motorola Axu4100 to transfer and try to receive signal to Motorola CP-200
Sep 03, 2010 | Motorola AXU4100 (10 Channels) 2-Way Radio
I have a set of T4525s and another set of T4508 Can they communicate with each other?
Hi
Absolutely no because
MOTOROLA T4508  frequency range: 409.7500-409.9875MHz
MOTOROLA T4525s frequency range: 462.5625-462.7250MHz
Aug 30, 2010 | Motorola Talkabout T4500 (7 Channels)...
Frequency range
The T5720 has
- 7 GMRS/FRS 1 watt Channels
- 7 FRS 1/2 watt Channels
- 8 GMRS 1 watt Channels
All of these frequencies are between 462-467 MHz. There is a list of the specific frequencies assigned to each channel on page 19 of the user guide. Here is a link http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Best regards.
Jun 16, 2010 | Motorola Talkabout T5720 (7 Channels)...
How can i change u.s. motorola radio frequency to u.k. frequencie
Sorry, but the freq range of these radios cannot be reprogrammed.
Bill B
Mar 19, 2010 | Motorola Talkabout T5500 (7 Channels)...
Motorola MJ270R Talkabout 2-Way Radios with 27-Mile Range Logo
107 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Damen Wong
Damen Wong
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
