SOURCE: feed dog is stuck
I have the same problem...this is a work around, not a fix. You need a small flat-head screwdriver. 1. Remove the clear bobbin cover. 2. Make sure the feed dog switch is in the DOWN position. 3. Slide the screwdriver under the feeddogs from inside the bobbin area & lift the feed dogs. 4. While holding the feed dogs in the up position, return the feed dog knob to the up position. You have to do this every time you put the feed dogs down...bummer, but I can find no broken part or adjustment that corrects this. If it's inside the machine body, I don't mess with it... I did take off the bottom plate in the feed dog area..one screw holds it.... there is nothing there to indicate a problem.
SOURCE: Viking Sewing Machine Model 6360
There is a white button on the front of the machine to the right - it has likely been pressed in to drop the feed. Press it in and release so the button comes out - that should solve the problem.
SOURCE: Feed Dog on Brother 270d stuck in up position
I finally figured this out. The feed dog switch in the back was not hitting anything when I moved it back and forth. There is a screw on the underside of the machine that I tightened. It seemed to do the trick. Thanks.
SOURCE: feed dogs stuck in down position
that the feed dog lever is in the up position. When the lever is in the
down position, the feed dogs will show on the top if there is no
pressure on them at all. Make sure that the machine makes one complete
cycle to check this. Just throwing the switch does not make them come
to the surface.
If this does not work, then the feed gear is broken and you will need to take it to a mechanic.
SOURCE: I have a Singer Stylist 513 & I cannot get the feed dogs raised.
you sewing machine's feeddog is called a pressure dial it is located on the left side of your sewing machine at the top above & to the left of the take up lever, it's a little dial it will have numbers on it, & possible a d on it for darning, move the dial to a number like 3 to 5 & see if it will start stitching.
