SOURCE: No printing threw terminal service
do you have the options set correctly on the remote computers assistant to use local devices
SOURCE: I would know if D-Link DP 301P Print Server
It supports all below protocol so you can give print from IBM iseries .
TCP/IP Protocols Supported
SOURCE: DP-301P+ Express EtherNetworkTM Fast Ethernet Print Server
You need to connect to it (using the broswer at the PC of same LAN with the current ip of the print server). Then click on Tools TAB, click on "Reset" at left. You should see "Do you want to restore this device to factory default setting?". Click on "Apply"
