High volume use caused unit to go down. No display lights, but only clicking sound while using power buttons.
SOURCE: SONY Receiver STR-DG510 does not turn on anymore.
Try, the fusível, if not work, try off the outlet 2 minutes, and plug in wall again.
-Verify the Voltage Selector too.
If after does not work, you need a techinical assistence.
SOURCE: STR-DH700 won't power up unless I unplug-plug it.
This is a logic problem with the internal microprocessor. A quick experiment: Turn the unit on for about 2 minutes and shut it down. Doe sit power uip in this case? If so, I'd suspect that the heat generated during normal operation is creating an internal problem thaty is preventing the micro from recognizing the "off" condition. The power data line is hung and is not being recognizwed by the micro so any attempt to turn the unit on will fail. The unplug/re-plug essentially clears or resets the unit.
If the unit is new, return it for warranty repair. It will be important to describe when the unit fails however. Try to see how long it must remain on for the problem to occur.
Update this with your results if the unit is not under warranty and we'll try to narrow it down.
Thanks,
Dan
SOURCE: Sony STR-DG510 hook up with BDP-S560 no sound
The Sony manual for this receiver is not wrong, it is just a little misleading.
It does in fact use HDMI but ONLY for the HIGH DEFINITION video portion of the signal, as output from the receiver to your television. High Definition Multimedia interface carries both audio and video, however, your receiver is not decoding the high definition AUDIO portion of it and passing it through the HDMI, nor is it passing any form of multichannel audio through HDMI. So you can see why the receiver is no longer available for sale from the Sony website. The HDMI connection on your receiver is redundant unless you are not using a multichannel audio format, in which case you would be using either the TV speakers or connect an additional audio cable from the TV's "audio out" back into the receiver for external speakers.
All that should be done is use the HDMI cable from your blu-ray player connected directly to your TV. That will give you your picture, and possibly a better one since the receiver will no longer be in the signal path.
Then connect either a coaxial or optical cable from the blu ray player to the receiver for your audio. You will then be able to have Dolby Digital and DTS surround formats.
Your service person was wrong.
Testimonial: "Thank you excellent report spot on with the hook-up. Will buy new receiver. John McMullan."
SOURCE: powers up, all lights buttons seem to work, but no sound
This can happen. Lightening causes static charge that can be picked up by speaker wires. It is possible ONE of the amplifiers has failed.
To check, have the room quiet. Turn on the amp. After 5 to 10 seconds there should be a nice solid 'CLICK' from inside the amp. If there is no click, the unit is in safety mode. You will need a service shop.
