I record drum/ bass and synth loops into logic and then send them to the rc50 loop pedal, i had 50 seconds of recording time left so i added a new track which left me 25 seconds of recording time, only for the loop pedal to tell me i had run out of recording time, i took another track out to make more room only for the loop pedal to tell me there is STILL no memory left, if i reset the loop pedal by taking all the tracks out to reset it, will that work to gather all the memory up and give me 200MB back again. Or is there any way i can add more memory to the rc50 loop pedal? Any way at all??? Please help.....
You can make a backup on your pc and load back Default settings or restore to default settings. Normally you should have I quote ' with up to 49 minutes of mono recording time (or 24 minutes in stereo), the RC-50 can function as a song recorder as well as a looper'
I have the RC300 which has 3 hrs recording time. But when i reach the limit. I make a backup and load back in a initial default setup which I have downloaded somewhere. But you can also restore to default from the unit itself. Hope this helps
SOURCE: guide on RC-50 won't turn off
First, you need to select one of the patches called "init patch", it won't have a drumbeat on it. Then, turn the guide on again, then all the way off. Even if the knob's in the off position when you go to the patch, it'll turn itself on again by default. There's a light there that says "beat quantize" that you want to be off, or it'll cut your loop to the length of whatever beat it's set to. If you want to change the default, turn the beat quantize off, then press "write" and write the new patch. Hope that helps.
SOURCE: How do I delete a track that has been 'written',
You didn't mention which model loop station you have so I'll direct you to the link:http://www.bossus.com/gear/productdetails.php?ProductId=477 The RC20XL for instance has an undo function.The RC50 has an update to ver.1.01 also that you can dowload. I hope this info helps.
Testimonial: "Thanks for the link, unfortunately it appears that there is no way to clear the memory once the write button has been pushed. Thanks for your help."
