SOURCE: my message keeps saying new flash player required but I cannot update it
click on the Tools icon in your browser... Choost Internet Options.. from there , choose the Security tab, click on the Custom button, and scroll down to the ActiveX Controls... look there for Download Signed ActiveX Controls... Choose to Prompt or Allow..( Enable)... then try messenger
SOURCE: Restore factory settings on a fujitsu siemens amillo pro
You should be able to fix this simply by inserting the original Cd that came with the computer and following the onscreen instructions.
Or the startup disks (if created) when you first used your laptop.
Alternatively If you do not have the one that came with your computer then you should be able to purchase one from ebay quite easily, and then insert it and follow the onscreen instructions.
I hope this helps you, Chris
SOURCE: reset my toshiba p300 laptop, to factory settings
The first thing you have to do is reset your windows password , There is a way to reset windows password without erasing anything.
Follow the instructions:
1.Free download the iso file : http://www.resetwindowspassword.com
2.Burn it to a disk to create the boot disk, that simple.
3.Configure your pc or laptop to boot in the cd drive,
4.Insert the CD, reboot from CD drive, and then just follow the process of instruction. A few steps later, admin password would be cleared
Took about 5 minutes for the whole process.
Probably means your factory restore is no good because it is created from a image that is either on cd's or the hard drive. Most times the restore does not work unless it is put on the hard drive by the manufacturer.
SOURCE: Hi, I'm trying to fix my friends Acer Aspire 5553.
try turning it on while pressing F8 to go to safe mode that might be one option
recovery disks are always a good thing to have on hand
Thanks but there aren't.
