Would like to know how to adjust the timing on my brother se270d. where to start and do I need to take the machine apart?
SOURCE: HELLO, WOULD YOU KNOW THE
I have seen this post before, perhaps the easiest thing for you to do now, after so long, is to just ring or email Brother or one of their dealers direct.
I do know that Janome recommend no more than 256MB CF card to reduce the need for searching through vast amounts of patterns.
SOURCE: I have a Brother 98-Stitch
I dropped my feed dogs and when I pushed the button to bring them back up, it wouldn't work. I did discover that when you put the button back to the up position and start sewing, the dogs come back up automatically.
SOURCE: need timing instruction for brother SE270d
Your needle thread lock on the bottom of your fabric and your bobbin thread locks on top. If you are getting jamming in the bobbin it is caused by the needle thread. Thread your machine with the presser foot up this will ensure thread going between tension disks.
SOURCE: Brother se270d
tighten the tension on the bobbin thread. or you are using the wrong size bobbin spool.
SOURCE: F01 trouble code
Do you have your manual? If, not just google brother.com and download one for free, also you can call Brother at 1-877-276-8437. Good luck
