Are these remote controlled dimmers? Do you have failing batteries in one of the remotes? Or perhaps a new remote control device has been introduced in or near your house that interferes with the dimmer remote signal. I had a similar problem that occurred when my boys played with their remote controlled cars.
SOURCE: touch dimmer malfunction
sounds like a loose connection to me, check to make sure all connections are tight. sometimes the bulbs themselves don't make a good connection in there socket.
u will have to take the switches out of the wall box and make sure the wires are tight, whether they are on screws or wires connected to wires. if it is wires to wires u may have to take that apart to make sure u don't have a bad connection there.
if it is none of that, then it is time to replace the switches
