Question about Jabra Extreme2 Bluetooth Headset
Volume does not adjust, when pressing the volume button up or down, jabra bluetooth tells me the status of the battery, but won't adjust the volume up or down
    New Friend:
    Problem Solver:
  • 13 Answers
I just got mine and had the same problem. After messing with it for I bit I got it to work. The trick is you must have audio of some kind playing through the jabra when using the volume button. I started some music playing and then tried the button and it worked. But if it is idle you just get the battery status.
Posted on May 30, 2016
2 Suggested Answers
SOURCE:
SOURCE: Cannot Get Jabra BT150 into Pairing Mode
I had problem with my bluetooth not getting into pairing mode,and Now it working good.
Thank you for your best solution.
Posted on Nov 17, 2008
I have a Jabra Clear that won't match up with my phone
The first thing I'd suggest you do is to turn your cell phone off and, if possible, remove its battery for 10 to 15 seconds. Then replace the battery and turn the phone back on. If taking the battery off the phone is not possible, simply delete everything on the Bluetooth pairing memory. Also, we will need to reset the Jabra headset to the factory settings.
Turn the headset ON. Then press and hold the volume down and answer/end buttons at the same time for approx. 5 seconds until the battery icon and Bluetooth® icon flash 5 times simultaneously - then the pairing list is reset.
Turn the headset OFF. The next time you power on, the headset will go into pairing mode as the first time you powered your new Jabra headset on.
Once in pairing mode, your cell phone should be able to add the Jabra headset as a new device from within its Bluetooth menu.
Nov 11, 2014 | Jabra Products - BT2080 Monaural...
I just got mine and had the same problem. After messing with it for a bit I got it to work. The trick is you must have audio of some kind playing through the jabra when using the volume button. I started some music playing and then tried the button and it worked. But if it is idle you just get the battery status.
Feb 23, 2013 | Jabra Extreme2 Bluetooth Headset
My jabra blue tooth asking for pass code , i tried with 0000 and 1111 and 1234 and 9999 but no use please help me
1. Put the headset in pairing mode
Make sure that the headset is on.
Press the answer/end button and press the volume up (+) button at the same time,
until a solid blue light comes on.
2. Set your Bluetooth phone to 'discover' the Jabra BT130
Follow your phone's instruction guide. This usually involves going to a 'setup,'
'connect' or 'Bluetooth' menu on your phone and selecting the option to 'discover'
or 'add' a Bluetooth device.
3. Your phone will find the Jabra BT130
Your phone then asks if you want to pair with it. Accept by pressing 'Yes' or 'OK' on
the phone and confirm with the passkey or PIN3 = 0000 (4 zeros).
Your phone will confirm when pairing is complete. In case of unsuccessful pairing,
repeat steps 1 to 3.
Jun 21, 2011 | Jabra BT130 Wireless Headset
My headset will not turn on
Hello
Your bluetooth headset is powered by an internal battery. If the battery is not charged,it just won't turn on. Fully charge your battery before use.
Make sure that the power outlet you're using is working and that the cord is fitted correctly into the wall, PC or Car outlet and the Jabra Bluetooth device.
Try unplugging the Jabra Bluetooth device and see if it turns on. If so, use the Jabra Bluetooth device until the battery is completely exhausted. The next time you charge it, check that it is charging properly
If the Jabra Bluetooth device is still not charging, check what happens when you initially plug the Bluetooth device into its charger. If the light on the Bluetooth device flashes on and then off again quickly, it is likely that the battery is no longer working. Batteries cannot be replaced or covered warranty
Dec 30, 2010 | Jabra BT150 Wireless Headset
I have a problem with my Jabra BT4051. I repaired it with my cell phone, and got a successful confirmation. However, there is no sound. The phone reacts as if the connection is right, but no sound. Please...
Check to see if volume button is not turned down It is a flat button located on the top and has a plus and minus sign on either end.Plus raises volume,minus lowers.
Nov 18, 2010 | Jabra Bluetooth Headset with Adjustable...
Cannot pair Nokia N70 to Jabra BT150 bluetooth headset
turn on cell phone. activate bluetooth. press right button to search for bluetooth devices. Then press the on button and the volume UP button at the same time on the Jabra headset. The cell phone then finds the device. put in the password/pin (usually 0000). and voila! it works
Dec 07, 2008 | Jabra BT150 Wireless Headset
How to conf jabra bt150 bluetooth for nokia n73
switch jabra off. switch cell on. turn bluetooth on. press "right hand" button next to middle button on cell to search for bluetooth devices. Hold down on switch and volume up switch TOGETHER on jabra. The cell then finds the jabra. I couldn't do this before I found Marie's problem below. Thanks for the info Marie!
Nov 29, 2008 | Jabra BT150 Wireless Headset
I do not have manual for jabra bt160 how do i connect to phone
Wear it how you like it 4
5
English
The Jabra BT160 is ready to wear on your right ear. If you prefer the left, gently flip and
rotate the earhook 180°. (See fig. 2 )
For optimal performance,wear the Jabra BT160 and your mobile phone on the same side
of your body or within line of sight.In general,you will get better performance when
there are no obstructions between your headset and your mobile phone.(See fig.5 )
Answer a call
Tap the answer/eend button on your headset to answer a call
End a call
Tap the answer/eend button to end an active call
Reject a call (DDependent on your phone supporting this feature)
Press the answer/eend button when the phone rings to reject an incoming call.
Depending on your phone settings, the person who called you will either be
forwarded to your voice mail or hear a busy signal
Make a call
• When you make a call from your mobile phone, the call will (ssubject to phone
settings) automatically transfer to your headset
Activate voice dialing (DDependent on your phone supporting this feature)
Tap the answer/eend button. For best results, record the voice-dialing tag through
your headset. Please consult your phone ’ s user manual for more information about
using this feature
Redial last number (DDependent on your phone supporting this feature)
Adjust sound and volume
Press the volume up or down (+or – ) to adjust the volume (See fig. 1 )
How to...5
Before you use your Jabra BT160, you need to pair it with your mobile phone.
1. Put the headset in pairing 2 mode
Press the answer/eend button and press the volume up (+) button at the same time,
2. Set your Bluetooth phone to ‘ discover ’ the Jabra BT160
Follow your phone ’ s instruction guide. This usually involves going to a ‘ setup,’
‘ connect ’ or ‘B luetooth ’ menu on your phone and selecting the option to ‘ discover ’
or ‘ add ’ a Bluetooth device.** (See example from a typical mobile phone in fig. 4 )
Pair it with your phone 3
English
Turn on your headset 2
Press the answer/eend button to turn on your headset
Press and hold the answer/eend button to turn off your headset
Charge your headset
Make sure that your Jabra BT160 headset is fully charged before you start using it. Use
the AC adaptor to charge from a power socket. Connect your headset as shown in fig. 3.
When the LED is solid blue, your headset is charging. When the solid blue LED turns off,
it is fully charged.
The Jabra BT160 is easy to operate. The answer/eend button on the headset performs
different functions depending on how long you press it.
Instruction:Duration of press:
Tap Press briefly
Press Approx: 1 second
Press and hold Approx: 5 seconds
Getting started
3. Your phone will find the Jabra BT160
Your phone then asks if you want to pair with it. Accept by pressing ‘ Yes ’ or ‘ OK ’ on
the phone and confirm with the passkey or PIN 3 = 0000 (44 zeros).
http://www.jabra.com/Sites/Jabra/UK-uk/support/Pages/JabraBT160.aspx
It is all in there www.jabra.com
ARTGIRL
Jul 18, 2008 | Lands Phones
Jabra Vibrate Feature
from the manual at http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT350/Documents/BT350_UM_NA_EN_491.pdf
Call vibrate*
• Call vibrate is automatically activated when you turn on your headset.
• To disable the call vibrate feature, press the answer/end button and
press the volume down (-) button at the same time.
• To reactivate the call vibrate feature, press the answer/end button and
press the volume up (+) button at the same time.
Dec 19, 2007 | Jabra BT350 Bluetooth Headset Headset
Jabra bt160
hold the button down for a long time
Apr 17, 2007 | Jabra COMMUNICATIONS BT160 Bluetooth...
Jabra Extreme2 Bluetooth Headset Logo
194 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Bobby G
Bobby G
Damen Wong
Damen Wong
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
