The loading diode of the right 19V laptop charger goes off when I connect it to th laptop, it does not if connected to my former Acer laptop. The reseller told me the motherboard needs to be renewed. It would be too expensive in relation to the price of a new laptop! Is this true, can I fix it myself.
Oh I guess.
(lol!)
By the way.......what the h3ll is a, "loading diode of the right 19V laptop charger"?
The Power On LED? (Light Emitting Diode)
HP Pavilion dv2000 series of Notebook PC motherboard?
http://www.ebay.com/itm/440769-001-HP-Pavilion-dv2000-dv2100-Series-De-Featured-DF-Laptop-Motherboard-/261162272180?pt=Motherboards&hash=item3cce7c05b4
Is $35 USD too much to repair your laptop?
Not advertising for seller nor website. Just from a quick search.
Suggest you cut out the middle man, (Reseller), and replace it yourself. Keep your hard earned money in your pocket, and stop listening to the prattle of that reseller.
One thing to bear in mind when it comes to the HP Pavilion dv2000 series, Pavilion dv6000 series, and Pavilion dv9000 series;
the cooling for the graphics chipset is INADEQUATE.
This is also a good time to fix that problem.
More on that later in solution.
HOWEVER, when purchasing suggest you contact seller, and ask what the return policy is if motherboard is no good.
Tell seller you are using an ESD wrist strap, and following Anti-Static Precautions; and this ain't your 'first barbecue'.
Which you better be. Wearing an ESD wrist strap, and have it's alligator clip attached to a good ground source.
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Wearing an ESD wrist strap, and having the alligator clip attached to a good ground source, ensures your laptop is safe from Static. (From you)
Average cost is $3 to $6. Here is an example,
http://www.radioshack.com/product/index.jsp?productId=2103245
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
I feel an Anti-Static Mat is unwarranted, and can explain in detail.
You can set a large metal serving tray (Unpainted), on the table you're working on; and connect to it.
You can also use a large metal knickknack (Unpainted)
http://www.alibaba.com/product-free/120807177/HannStar_J_MV_4_Motherboard_with.html
Use a multi-compartment container, for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws.
Advise do NOT mix them up.
Make a personal record as you disassemble. Make notes and drawings if needed. Take photos, or use a video cam. (Use good lighting)
It's nice to have a Service Manual, but even nicer to have your OWN personal information too.
Service Manual,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=1817074&
Scroll down a little. Click on the first file listed,
HP Pavilion dv2000 Notebook PC Maintenance and Service Guide
[Ignore if you are aware. This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name it may take up to 30 seconds, before the first page will come up.
the PDF file will not show until it is fully downloaded.
After the file has downloaded, suggest go to the Top Left corner, and click on the Toggle Slider icon.
Then click on the icon to the right - Show Document Outline.
This way you are also looking at the Bookmarks menu ]
The Illustrated Parts Catalog starts on Page 65.
There is an exploded diagram of the computer's major components, on Page 66,
3.2 Computer Major Components
Page 183 - System Board, deals with replacing the motherboard.
The components are listed in an order of removal.
Let's use the first one as an example;
Hard Drive (Section 5.4)
Click on the blue Section 5.4
Takes you to removal of the Harddrive. Now you want to go back to the page where you were, so you can remove the next component in the order of disassembly.
Page 183
At the top of the PDF file is the page number box. It is to the right of the Down Arrow.
1) Put your mouse cursor in the page number box. Left-click once.
2) Type the page number 183
3) Press the Enter key
http://www.youtube.com/watch?v=MwDm6qUhHcI
http://www.youtube.com/watch?v=dkYq7dQyc7E
Adding copper sheeting for repair on inadequate cooling problem,
http://www.youtube.com/watch?v=JEpnqhRYGLw
Reflowing is not necessary. Just add surface area.
Board level component repair.
You'd be replacing Power MOSFET's. Maybe a Diode, or two also.
(SMD/SMT diode)
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
The above is for the HP Pavilion dv6000, and Pavilion dv9000 series of Notebook PC's.
Can be crossed over to the Pavilion dv2000 series, also.
The Power MOSFET's will be close to where the DC Power Jack is, on the motherboard.
(The DC Power Jack is where the AC adapter {Charger} plugs in)
Using the above example, and the Power MOSFET's used on it;
Fairchild Semiconductor Industries - FDS6679 - Power MOSFET,
and,
Alpha & Omega Semiconductor Ltd - AO4407 - Power MOSFET;
,let's look at availability, and price,
http://www.mouser.com/Search/Refine.aspx?Keyword=FDS6679
Scroll down a little. Here we see the FDS6679 is obsolete.
Let's use the cross replacement FDS6679AZ,
http://www.mouser.com/ProductDetail/Fairchild-Semiconductor/FDS6679AZ/?qs=sGAEpiMZZMshyDBzk1%2fWi1qxDdW%2fXBi2qgMuZEfLVO4%3d
$1.01 USD
AO4407,
http://www.mouser.com/Search/Refine.aspx?Keyword=AO4407
Here we see it is obsolete too.
Using cross reference DMP3020LSS-13 for an example,
http://www.mouser.com/ProductDetail/Diodes-Inc/DMP3020LSS-13/?qs=%2fha2pyFadujguNNSgppBRqXbOxXLwzGsZm9SWxz1EqWpzoSJOpHpWA%3d%3d
.78 Cents USD
http://www.youtube.com/watch?v=3NN7UGWYmBY
http://www.youtube.com/watch?v=5uiroWBkdFY
Short answer?
NO, I do not agree with reseller, lol!
Granted not everyone wants to attempt board level component repair, but replacing a motherboard isn't that difficult. I have taught two
9 year old children to do it.
So................$35 USD to $70 USD for a replacement motherboard, is going to = a new laptop?
$229 motherboard isn't going to = a new laptop.
For additional questions please post in a Comment.
Regards,
joecoolvette
Testimonial: "Dear joecoolvette, Reading your expert comment on the motherboard problem I feel stupid, which is the truth concerning this subject. I toasted the Hannstar J MV-4 94V-0 motherboard in an ACER Aspire 7745G and not in a HP Pavilion dv2000 series of Notebook PC. Untill now I didn't succeed in finding the proper mainboard "Hannstar J MV-4 94V-0 1012" (1012 was written on the board itself as :0: 2). Yet I think I will succeed in repairing my laptop for less than $80-$90. I will keep in mind your advise about the the cooling for the graphics chipset, which is known to be inadequate for the most ACER series.Thank you for your detailed manual. Peter"
Acer Aspire 7745G Service Manual,http://www.tim.id.au/blog/tims-laptop-se... Go to the 'paragraph' that starts with Aspire 1200. (1200 in blue) Drop down to the 12th line (7530), scroll across, click on the blue 7745G. (PDF file also) Thank you for the rating, and appreciate the comments! Regards, joecoolvette
