Xerox WorkCentre M15i Laser Printer Logo
Posted on Feb 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Workcentre M15i won't turn on after poss outlet short
M15i was plugged in while in "on" position. It flipped breaker. Outlets working fine but cannot turn on machine. There is no "reset" button visible. Closest service is over 60 miles away. What do you suggest?
  • drwillyankem Feb 17, 2009
    No go. Tried that before. Outlet is definitely working. Is there an internal reset button or breaker?
    Thanks for the info. However, that is if the machine is on. Juice isn't getting that far. I still think there is a reset button, internal breaker, etc. Keep smiling
Anonymous
Level 2:
  • Expert 51 Answers
  • Posted on Feb 17, 2009
Anonymous
Expert
Level 2:
Answers
51
Questions
Helped
17235
Points
113
Turn it off
unplug it
wait a few minutes
plug back in
turn on
  • Anonymous Feb 17, 2009
    go here
    http://www.google.com/search?hl=en&c...
    go to the second link to the manual
    go to page 167
Louisann pellet grill series 900 ? model# flips breaker everytime when powered on. Why? Has never done this before.
need to test for short or jamming --with motor and other components - circuits
Jul 25, 2018 • Grilling
Breaker in garage flips after installing new 3 way switches and outlets
go back and check the wire colors on the devices that trip the breaker
Lights and outlets on one side of room work,outlets on other side of room do not work. no juice to either outlet.
Have you checked the breaker box? Usually this is a thrown breaker; flip the switch, by turning it completely off, then back to on.
1helpful
Two of the electrical outlets in our kitchen have no power. I checked to make sure the connections were tight and they were, still no power. Then I replaced both of them with new receptacles (ones that...
Each outlet receives power from previous outlet box or switch box in a long chain of parallel wiring back to ceiling box, or junction box, and then back to circuit breaker.
Use process-of-elimination to find problem.
Locate all boxes on same circuit breaker. Locate box before the two dead boxes... it can be in ceiling light, or switch box, or outlet box. Then test those wires. Look for loose quick connect where wires are pushed into hole on back of device, or loose white wires twisted together and shoved to back of box.
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/How-to-wire-switches.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
ONLY one of my circuits (out of 25) is
First off do you have anything plugged in to any of the outlets that are on that breaker? If so unplug and try resetting the breaker again. If not you may have a faulty plug. Go to lowes or a good hardware store and buy you a circuit tester for plugs they make them that plug in and have lights that will light up and give the error or what is wrong with that plug. It sounds like your overloading the breaker.
Daughter's TV was on during bad electrical storm. Screen went black and made high pitched sound. cable, internet and telephones all digital through Time Warner Cable. Now TV will not even turn on;...
Ur Main Fuses in the circuits breaker box must be to be restart it back.Turn off/on all the fuses on the main circuits breaker box to all the fuses in the box of the box to restart.All ur electical power outlets should work again.If not those power plug in outlets are shorted and dead must have to be replaced.
We have recently lost power to one end of our trailor the breaker flipped yesterday and now we can get nothing there is nothing plugged in now so what could be keeping our breaker from working
I just recently fixed the same problem, and it turned out to be a bad outlet or plug in. Starting with the farthest room that is dark remove the outlets one by one and look for a blackened one. Replace it and repair any burnt wiring with some shrink tube to make sure it will not short out. You can get a tester for less than $10 that looks like a square pen and will let you know if there is power present just by placing it next to wiring or outlets. When in doubt, turn off everything!
Mar 13, 2011 • Garden
Ceiling fan just stopped working. Turned on
did any outlets stop working, mat be a tripped or bad breaker in elect. panel she if one breaker is tripped. flip off and back on, could se short in fan but unlikely. if cannot see tripped breaker, turn off computor, tv, any appliance you have on and go down breakers and flip off and back on. if a short is present one breaker will trip back off. call repair
Circuit breaker
SOUNDS LIKE TO ME THAT YOUR DEHUMIDIFER HAS A SHORT. SOME TIMES ITS THE PLUG OR THE CORD BUT MOST TIMES IT GETS OXIDATION FROM MOISTURE INSIDE.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
