Sony Cyber-shot DSC-T900 Digital Camera Logo
A
Anonymous Posted on Feb 23, 2013
Reset factory Sony Cyber-Shot DSC-T900 - Sony Cyber-shot DSC-T900 Digital Camera
5 Related Answers
Anonymous
  • 10594 Answers
  • Posted on May 27, 2008
SOURCE: reset factory settings of sony cyber shot DCS-S650
Hello rkhanna,
Initialize function reset all data/ settings to factory defaults including date. I think, LCD Back Light of your cyber-shot is not working and its hardware problem. Contact nearest Sony repair shop.
Anonymous
  • 36 Answers
  • Posted on Feb 10, 2009
SOURCE: Sony Cyber-shot DSC-W30 Digital Camera
If you want to reset DSC-W30, press Menu and go to Initialize, select it and press OK
Camera will be RESET and go to factory default settings.
ripleymojica
Mando Mojica
  • 643 Answers
  • Posted on Jun 01, 2009
SOURCE: My Sony Cyber-shot DSC-W200 flash has stopped working and when I try to reset it it tells me that flash cannot be reset. What can I do?
its circuit error need to replace flach unit
Anonymous
  • 2185 Answers
  • Posted on Nov 13, 2009
SOURCE: NEED DOWNLOAD FOR SONY CYBER-SHOT DSC-W80, I LOST
Would you like to open your pictures from your Sony Cybershot to your computer? Your cybershot cam is usually plug and play so you dont need a software for that. All you do is to plug in your camera to your computer's usb port using the usb cable. When the computer detected the new usb device, open a Windows Explorer. Right click your windows Start button, and choose Explore. From the list of Drives from the left, you need to find the Drive letter associated with your camera. Just click on that and it will show you the files on the right. The pictures are located somewhere inside those folders. You just need to click and drag them to your computer's local drive.
Should you have any questions, please let me know. Good luck!
Barry Boyd
  • 101 Answers
  • Posted on Mar 23, 2010
SOURCE: I got a sony cyber-shot dsc-t900 what is error
The error is: E 61 10 Zoom operations fault Inspect the lens block zoom reset sensor
Here are some things that are reported to work:
Reset the camera:
Home>Settings>main settings>Initialize>ok
If that doesn't work give the camera bottom a couple of slaps against the palm of your hand or strike the bottom against a book to knock the lens mechanism back in place. Be resonable with the force, you don't want to break the thing. It may take a half dozen wackings to get things settled.
Hope that helps,
BAX
4helpful
2answers
I got a sony cyber-shot dsc-t900 what is error 61:10?
Reset the camera:
Hope that helps,
BAX
2helpful
2answers
Getting an error code c:13:01 on my sony t900 camera
“Memory Stick Duo” is unformatted.
“Memory Stick Duo” is broken.
“Memory Stick Duo” type error
The camera cannot read or write data
on the “Memory Stick Duo”.
Format the “Memory Stick Duo”.
Replace a new “Memory Stick Duo”.
Insert a supported “Memory Stick Duo”.
All above are solution for your quiry
Can,t burn video dvd from videos taken on dsc-T900
You need a dvd video burning program on your computer. Do you have one?
My DSC-T900 keeps turning off
How often and how frequent does it shut off? As soon as you turn it on? How long have you owned it and how long have you had this problem? Most likely you are going to want to send the unit in for repair you can do that at this link:
https://eservice.sony.com/webrma/web/index.do
Thank you,
Lee
How to connect Sony Cybershot T900 to usb port
reference page 44 of the manual for step by step instructions on connecting your t900 to the computer.
http://www.docs.sony.com/release/DSCT900_EN_ES.pdf
Thank you,
Lee
Where to connect the usb cord on a DSC-t900 camera?
Here is how to hook up camera to computer.
Good luck and please rate
2helpful
2answers
Sony Cyber-shot DSC-W30 Digital Camera dsc w30 digital camera reset
2helpful
Reset factory settings of sony cyber shot DCS-S650
Hello rkhanna,
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
