I can't adjust the time, the screw that is supposed to adjust the time does not pull out. The glass face is broken, where can I get a replacement?
Hi rmanllo
It seems that you need to buy a new strap for your watch.
You can go to the following link:
http://www.cartier.com/show-me/accessories#/contact-us/contact-us/send-a-message
Give details about your name , email id, country of residence.
Write in the message box that you need to buy a new strap for your Cartier 21 Autoscaph W10147U2 Watch for Women.
They will get in touch with you shortly.
Hope this helps
Regards
TDCL
Place the watch face-down on a clean towel to protect the crystal.
Gently unscrew the backplate from the watch with a small jeweler's screwdriver and set it aside.
Locate the battery compartment and remove the screw holding the cover in place, using the screwdriver. The battery is a small, round silvery button.
Make a note of the battery polarity before you remove it. Is the battery positive (+) side up or negative (-)?
Take the battery with you to a watch shop or electronics store to buy a replacement.
Insert the new battery in the compartment. Replace the battery cover and reverse the above steps to reattach the back cover of your Peugeot watch
