If your problem is "switch on then after 10secounds shuts down and
protect appears on the display .and cannot do anything with it but turn
it off"
Then the unit is on protect mode, that is a special diagnostic mode that starts when the unit detects an internal fault.
To start unplug the unit from power for ten minutes, and see if this reset the protect mode, I guess you have done this already.
The
first thing to do is to start the unit with nothing connected, if the
unit does not go to protection, then the problem was one of the cables
or a connected device.
If that does not fix it , there is a
master reset , by pluggin the unit into main while at the same time you
hold the power button.
If still no luck then the unit is defective and must be taken apart and tested with a multimeter.
You
start checking for burnt areas on circuits, cold solder joints and
leaking capacitors at sight, then there is need to grab the multimeter
and do the real testing job.
When you find the problem you do the soldering.
Naturally this requires a certain experience in fixing electronics, to complete the job usually a precision soldering is needed.
The protect mode indicates that a problem was detected in the final stage of the output amplifier. The unit is shutdown to prevent further damage to either the amp or the speakers. I don't kow the specifics fo your model, but if it has discrete transistors for outputs, the parts cost will be in the $15-$25 range. If it have an AMP pac, expect parts to run in the $60-$75 range.
Dan
I have the same problem with the HT-SL5, but then after approx 2 hours
when the amplifier is warm, the middle speaker makes a loud noise and
the display gives PROTECT. By switch of and on again the PROTECT
indication is dissapeared. I have disconnected all speakers and inputs.
The fan is running by power on and no burned components are located
inside.I hope that someone has the electronic diagram off the sony HT-SL5, it can be help by fixing my problem.
Richard
