I am trying to use the wi-fi feature on my galaxy S III and have a D-Link router that works to access the internet for a laptop. Have tried using the wps push button on the d-link and while in the wps setup section of the phone. Its says WPS is complete and says it is connecting, but never finishes. Is there something that needs to be done that I am missing?
SOURCE: D-link dir-615 cannot connect to internt
it could be a problem with your internet connectivity. check with the isp.
SOURCE: D-Link DIR-615 Internet LED light not working
Even though we need more info to resolve the issue, I will make a guess here. My guess is that your D-Link is not configured right, (ie. not pulling the proper info from your ISP's DHCP server.
Try restarting the router and restart or repair your network connection on your pc. Secondly, try to do a "hard reset" on the router, or restore to default. Then reset your connection on the PC. Third, manually set the info on the router.
If you are wireless, you have a whole different issue.
SOURCE: Using a HN9000 modem and D-Link dir 615 together
change your routers IP address to IP address. 192.168.1.1.
SOURCE: How to configure D-Link Wireless Router 615 on LAN ?
The following procedure should get you a connection with any broadband
modem that is configured to use DHCP for the router connection, such as
cable modems, and many DSL modems. If you require PPPoE configuration
for the DSL modem, that will have to be configured to match the ISP
requirements.
Note that the wireless encryption and channel selection will have to be
done after the basic wired connection is established, the first step is
to get wired connections working.
When the computer is completely booted, let's see this.
Hold the Windows key and press R, then type CMD (COMMAND for W98/WME) to open a command prompt:
NOTE: For the items below in red surrounded with < >, see comments below for the actual information content, they are value substitutions from the previous command output!
In the command prompt window that opens, type type the following commands one at a time, followed by the Enter key:
IPCONFIG /ALL
PING <computer_IP_address>
PING <default_gateway_address>
PING <dns_servers>
PING 206.190.60.37
PING yahoo.com
Right click in the command window and choose Select All, then hit Enter to copy the contents to the clipboard.
Paste the results in a message here.
<computer_IP_address> - The IP Address of your computer, obtained from the IPCONFIG command above.
<default_gateway_address> - The IP address of the Default Gateway, obtained from the IPCONFIG command above.
<dns_servers> - The IP address of the first (or only) address for DNS Servers, obtained from the IPCONFIG command above.
SOURCE: I forgot my password to
To reset the D-Link back to the default settings, Press and hold the RESET button and then power up the D-Link. Hold the RESET button for 5 secs until the LEDs flash.
Now you can enter the default login & password.
