Rothco Aquaforce Watch-combat N/a Logo
Posted on Feb 22, 2013
I need to set the correct time on my aquaforce watch.
Everytime i try to set the time, it sets the alarm instead of the actual time
I bought a watch for my grandson. It had no instructions. It is from China MFG# FMDAW549. Are there directions available
Possibly these instructions:
http://forums.watchnet.com/index.php?t=tree&goto=110449&rid=0
DIGITAL WATCH USER INSTRUCTIONS May 27, 2006 - 05:59 PM On 5/26/2006 I bought from Walmart a $6.43 watch, on the back of which is written "AH 1175, 52, Battery CR2025, China Module, FMD, Base Metal Bezel, Stainless Steel Back, 100ft Water Resistant". It has no control buttons on top (where buttons may be accidentally pushed), the display is larger and more visible, and the color is dark, so I bought it even though I prefer models that have a fabric/velcro wrist-strap.
Four buttons on this watch are labelled: Light, Mode, Reset, and St/Sp. The instructions which I found inside its container refer to the Light button as A, the Mode button as B, the Reset button as C, and the Start/Stop button as D, but otherwise do not pertain to the watch, so I determined the button's functions by trial and error, as follows:
TO SELECT THE DISPLAY MODE
Push the Mode Button in order to select one of the following four display modes in the following order: Normal Time, Stop Watch, Alarm Reset, Time Reset.
In the Normal Time Mode, the Day of Week, the Hour, Minute and Second are displayed (none flash). If the Alarm and Hourly Chime icons are not displayed, the Alarm and Hourly Chime are turned off.
TO DISPLAY DAY OF WEEK, HOUR, MINUTE, SECOND AND WHETHER THE ALARM AND HOURLY CHIMES ARE ON:
Push the Mode button until no icon is flashing. The Alarm and Hourly Chimes are off if no Alarm or Chime icon is displayed beside the Second display.
TO DISPLAY THE DAY, MONTH AND DAY OF WEEK AND WHETHER THE ALARM AND HOURLY CHIMES ARE ON:
In Normal Time Mode, push the Start/Stop button. The Alarm and Hourly Chimes are off if no Alarm or Chime icon is displayed.
TO DISPLAY THE ALARM TIME
In Normal Time Mode, push the Reset button. The P or A beside the Alarm Time indicates PM or AM time. The P or A below the Alarm Time indicates a 12 hour clock; an H indicates a 24 hour clock.
TO STOP/START THE ALARM AND HOURLY CHIMES
In Normal Time Mode, hold the Start/Stop button down and push the Reset button (the Date and Day of Week will be displayed) to turn the preset Alarm and Hourly Chimes on, or off (to save the battery). To test the alarm, hold the Reset button down. The alarm and chimes are off when the alarm and chimes icons are not displayed.
TO STOP THE HOURLY CHIME
In Normal Time Mode, hold down the Reset button (the Alarm Time will be displayed) and push the Mode button until the Day of Week display is no longer highlighted; otherwise the hourly chime drains the battery.
TO SET THE TIME
To Fast/Forward until the correct number is displayed, hold the Start/Stop button down.
To set the Month of the Year, select the Time Reset Mode and push the Reset button until the Month of the Year number flashes; push the Start/Stop button until the correct Month of the Year is displayed and push the Reset Button.
To set the Day of Month, select the Time Reset Mode and push the Reset button until the Day of Month number flashes; push the Start/Stop button until the correct Day of Month is displayed and push the Reset Button.
To set the Day of Week, select the Time Reset Mode and push the Reset button until the Day of Week display flashes; push the Start/Stop button to until the correct Day of Week is displayed and push the Reset Button.
To set the Hour, select the Time Reset Mode and push the Reset button until the Hour number flashes; push the Start/Stop button until the correct Hour is displayed and push the Reset Button. For a 24 hour clock, push the reset button until an H is displayed. For a 12 hour clock, push the reset button until an A or P is displayed.
To set the Second, select the Time Reset Mode and push the Reset button until the Second number flashes. The Second number resets to Zero everytime the Start/Stop button is pushed. If the Start/Stop button is pushed as soon as the Second hand on your computer and watch are the same, the watch will be accurate to one second (to set your computer time to the second, log on to the Internet, right click on your PC's time display, select ADJUST DATE/TIME, INTERNET TIME, UPDATE NOW). The setting of the Second number will not be affected by setting the Minute number afterwards.
After the Second number is set, set the Minute number by selecting the Time Reset Mode and pushing the Reset button until the Minute number flashes; push the Start/Stop button until the correct Minute is displayed and push the Reset Button.
TO SET THE ALARM TIME AND TURN ON THE ALARM
Choose the Alarm Reset Mode. The alarm is turned on everytime the Alarm time is reset.
To select the Hour, push the Start/Stop button while the Hour is flashing and until the correct Hour is displayed, then push the Reset button (the Alarm and Hourly Chime icons will appear).
To select the Minute, push the Start/Stop button while the Minute is flashing and until the correct Minute is displayed, then push the Reset button.
Push the Mode button after the correct Alarm Time has been selected. The Alarm and Hourly Chime icons will be displayed beside the Second numbers.
The P icon indicates PM. The A icon indicates AM. The H icon indicates a 24 hour clock.
TO USE THE STOP WATCH
Choose the Stop Watch Mode. Push the Start/Stop button to begin the lap time. To pause the Stop Watch push the Start/Stop button to stop it and push it again to continue. To reset the Stop Watch to zero, stop the lap time by pushing the Start/Stop button, then push the Reset button (otherwise the Stop Watch will continue counting after other Modes are selected).
Apr 20, 2018 • Watches
I have an alarm chrono watch from walmart and I can't get it to back to 12-24 hour display
For most of the cheap Chinese digital watches sold at Walmart you simply scroll through the different numbers while setting the hour part of the time -- 1 to 12 then 13 to 23 to 0 then 1 to 12 AM and 1 to 12 PM then 1 to 12 to 13 etc. When the watch is in 24 hour time (as used by most of the world outside the US and Canada) most will show the letter H instead of A or P.
For some of these watches, you need to be in Alarm set mode to be able to scroll through all the choices, and that will control how both the alarm and the watch show time.
For a few others, you get to select A or P or H separately from the numbers, either while setting the time or while setting the alarm.
The Chinese factories that build these watches seem to put any of the different kinds of insides into any of the same cases, so you might have any version -- and the companies rarely bother making sure that the instructions match the actual watch.
3helpful
Alarm won't turn off on Zoo York watch.
I have a different model but this solution came up in Google and it didn't work. On mine, I tried the following: press MODE. It will show the alarm time. Then press ST/SP a few times until the little alarm icon does not show on the alarm face. If you press RESET instead of ST/SP, it will start blinking and will want you to change the alarm time instead.
Mar 14, 2012 • Watches
2helpful
I have an aquatech watch and don't know how to set it.
Thank you for contactng FixYa.
Setting the Time and Date
  • To set the time and date on your Aquatech watch, begin by pressing the "Mode" button three times to access the time setting screen. Use the "Lap/Reset" button to set the hour on your watch. Use the "Start/Stop" button to advance the numbers to reach the correct hour. When you've set the hour, use the "Lap/Reset" button to set the minutes, using the "Start/Stop" button to advance to the correct minute. Repeat the procedure to set the seconds, month, date and day of the week on your Aquatech watch.
  • Setting an Alarm
  • To set an alarm on your Aquatech watch, begin by pressing the "Mode" button two times to access the alarm setting screen. Use the "Lap/Reset" button to set the hours place, using the "Start/Stop" button to reach the correct hour. Repeat the same procedure to set the minutes for your alarm. When you have finished setting the alarm, activate it by simultaneously holding the "Lap/Reset" and "Start/Stop" buttons until the alarm icon appears. When the alarm sounds, silence it by pressing the "Lap/Reset" button.
  • Deactivating the Hourly Chime
  • Many Aquatech watch models feature an automatic hourly chime. This can be inappropriate and inconvenient in many situations. To deactivate the hourly chime on an Aquatech watch, simply press and hold the "Lap/Reset" and "Mode" buttons simultaneously. After you have correctly deactivated the hourly chime, the hourly chime indicator icon will disappear from the watch's main screen.
  • Best regards. Jewel
    Sep 18, 2010 • Watches
    1helpful
    When I pull out the crown to the second place, the alarm time does not match the watch set time. How can I correct this?
    Imbahe,
    Here is the procedure to make the alarm time match the you you have set for the main watch time:
    2. ALARM HAND ADJUSTMENT
    Hour hand Minute hand
    B
    ALARM
    hour hand ALARM minute hand
    B Press repeatedly to set ALARM
    hands to the time indicated by the
    main time hands.
    ? Set the ALARM hands to the time the main
    time hands indicate.
    * The ALARM hands move quickly if
    button B is kept pressed.
    Then press the crown all the way in when finsihed.
    Your watch is caliber 7T62. You may download a complete settings instruction manual for this caliber here:
    http://www.seikowatches.com/support/ib/index.html
    The instructions you need are on page 3 of the manual. I hope this will fix your problem with the adjustments. If you need more help, please let me know.
    Regards, Bill
    4helpful
    3answers
    I have a wacky wake up timex alarm clock and can't set it to correspond with daylight savings.
    You press and hold down the time set button...once the time starts to flash you use the "fwd" or "rev" buttons to change the time to what you want it set to. The alarm is set the same way...just press and hold the alarm set button until the time flashes. :)
    4helpful
    2answers
    Echo drive calibre 2100 - How do I set the alarm?
    Now sure if you are still looking for a solution or not but just came across your problem. The lower right-hand button, the one used to turn the alarm off and on, can actually be pulled out to set the alarm. Pull out the knob, adjust the alarm time, push back in and push one more time to actually set the alarm. Hope this helps.
    How to set the alarm?
    Just answered this question for someone else so I thought I would just copy and paste my response.
    Citizen AV0031-59A
    In case you didn't get the other one.
    Kenneth Cole Reaction Watch Model KC1450 digital settings
    hold down mode until the time settings come up. the alarm settings show first, then press mode once more to set the actual time.
    bing took me like 2 hours lol.
    Top Rothco Watches Experts
    john h
    ADMIN Andrew
    ADMIN Andrew
    Ngoro
    Are you a Rothco Watch Expert? Answer questions, earn points and help others
