It will play only in the left headphone. I have tried several pairs of headphones with the same results. Any ideas?
Step 1:
Your trusty iPod has been a close and reliable friend for a long time but one morning only the sound of air comes through the headphones. The likely culprit is a loose or broken headphone jack that is in need of repair. Rather than spend an exorbitant amount of money to have someone fix it you can easily make the repair on your own and have your iPod friend back. Read on to learn how to fix a broken headphone jack for a fifth generation 30GB or 60GB iPod video.
Open the iPod case with a small flathead screwdriver by slipping it under the centerline of the case. You will find a series of clips you have to release in order for the case to open up about an inch. Locate the headphone jack connection and verify that there are no broken wires. Fix broken wires quickly by twisting the wires back together and wrapping with electrical tape. Test the iPod for sound by connecting your headphones to the jack. Replace the wires completely if you find static coming from the iPod jack. Fold a business card twice so that it wants to unfold and slip it into the case over the blue sponge. This creates the pressure needed to hold the jack in place and allow a solid connection. Push the case together without engaging the clips on the side and test to make sure the jack is now working. Try a thicker business card or fold the first one again to get enough pressure onto the jack connection if the first card didn't fix the problem. Press the case fully together until the clips click into place. Use extra care when inserting your headset to ensure the jack remains in place.
DigiExpress - iPod Video / iPod Classic Headphone Jack installation
http://www.youtube.com/watch?v=MXXgV6YNGkQ
SOURCE: ipod Nano 1st gen 4gb. Headphone jack signal in mono, not stereo.
most likely headphone jack is broken. option one is to take it to the apple store and have them repair it. option 2 is to go on e-bay and buy a replacement jack and try to do it yourself. best option is to sell it on ebay as broken/needs repair. Someone who knows how to fix them will buy it from you and you can use the money you get to buy a good used working iPod. There are always tons of nanos for sale on ebay.
SOURCE: headphones not playing in iPod
This is either cause by a damaged headphone socket in the iPod or a loose connection. The only way to solve it will involve opening the iPod case and inspecting the daughter board that the headphone socket is on.
SOURCE: My ipod doesnt only works out of one headphone.
HI,
I actually had the exact same problem with my ipod touch. It's actually not a problem with the headphones but with the headphone jack on the ipod. For a while i "solved" this problem by wrapping my headphone wires twice around my ipod [so it was tight and the sound could be heard, the same way u do it by pushing it with ur finger]. Well one day my ipod jack just fixed itself, I got lucky. But my advice to you is to send it into apple like my friend who had the same problem did, they sent him a new one [hopefully u have a warrenty!]
hope that helped!!..thank you!!..
SOURCE: no sound through headphones in ipod shuffle.
Player may require formatting. Try after formatting.
SOURCE: when i plug my headphone in my ipod 5 genration it plays out loud
Try getting a can of compressed air to blow out the headphone jack sometimes dirt gets in there. Don't blow with just your mouth. If this works try keeping headphone jack covered so dirt doesn't get in there. Switcheasy makes doc and headphone port covers they come with their cases.
