Hi, You can unlock a Sony Ericsson Xperia safer and easier using unlock code. You can get the accurate unlock code for a Sony Erisccson Xperia from www.MobileUnlockSolutions.Com at affordable cost with free step by step unlocking instructions. Good luck mate.
SOURCE: sony ericsson xperia x10 unlock code
You can get the unlock code by contacting your current service provider customer care department.If your phone is locked you can use any of your friends phone to make this call. The service provider will then provide you the unlocking codes.. Remember that the reason why the codes are provided only thro customer service provider is they will make a check on your name and identity proof at the time of your call. If the information is found to be correct and matching with their data then you will be provided with the codes. Everything is done for free of cost and you are not going to be charged for this process.This is the universal solution and is useful for many customers who are facing these kind of problems. Don't believe in any websites which provides unlock codes. All are fake. Only your service provider can provide these codes.
Thank you !!
SOURCE: how do i unlock my sony ericsson xperia x10 phone?
Use this following steps to unlock your mobile
- Switch ON your Sony Ericsson Xperia X10 without any
SIM Card,
2 - Press the left arrow key/button once,
3 - Press the button * twice,
4 - Press the left arrow key/button once,
5 - The message "Personalize with MNC2" will appear, (or you will have
displayed an unlock menu, select the lock you want to unlock)
6 - Enter the Unlock Code.
And also get the unlock code here theunlockarena.com
SOURCE: How do I unlock my sony ericsson xperia x10
You can unlock it via unlock codes..you can either get from your provider or can get it online..one of my friend got unlock code for his mobile from prounlocking and got his mobile unlocked..you can too try unlocking your mobile by unlock codes..
1. Switch ON your Sony Ericsson Xperia X10 mini pro with a Not Allowed SIM Card.
2. Your Sony Ericsson Xperia X10 mini pro will request to enter an unlock code.
3. Tap the box where you have to input the code and a number pad will appear.
4. Type in the unlock code we send to you.
5. Press the 'Unlock' button on the phone.
6. Your Sony Ericsson Xperia X10 mini pro phone should now be unlocked.
*NOT ACCEPTED : We mean, to use a sim card from a network other than the network your Sony Ericsson Xperia X10 mini pro is locked to.
Instructions
Unlocking Instructions for Sony Ericsson XPERIA X8
How to insert the Unlock CODE into your Sony Ericsson XPERIA X8
