You have a defective bulb. Unfortunately it does happen. If you bought just the bulb, then don,t do that again. Always buy a new bulb with the housing and don\'t touch the bulb eith your hands. Most bulb sellers warrant their bulbs for at least 3 months. Some warrant for up to one year but you pay a little more, about $80-100. If you bought the $35-45 bulb (made in china) then you get what ya get. Nothing against the chinese, just the people who pay them 30 cents an hour to make a product extremely fast with no care for quality control. The chinese are hard working people. Chinese products are made to be disposable on purpose so you can buy a new something more often.
SOURCE: KDF-55W655
red light blinks in 5 times then pause and then repeats. It is the lamp error. " Lamp Driver Defect"
When the "LAMP-PORT" (pin 95) is low, the lamp is not turned on. If the "LAMP-HV-DET"(pin 96) is low at the same time, it is classified as no high voltage of the lamp driver. I'm guessing it needs a Lamp driver which I think is on the C Board, which is part of the "Optics Unit Block Assy. The C Board cannot be orderd separately, and Optics Unit Blocks are not cheap. Good luck
Bobby G aka poolmvp1
SOURCE: please help
That is the blink code for the lamp ballast. Here is the more complicated explanation from the service manual.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp is blown
Hope this helps.
SOURCE: Cannot see picture....
you probobaly. need a new bulb, my dad had the same problem. he orderd a new bulb off the internet and now it works just fine
SOURCE: power light flashed red 4 times then repeats no pic,new bulb/fan!
Check the fan that cools the bulb. It is directly behing the bulb. It should turn on when the power comes on. It apparently has a safety to protect your tv(and home). mine is in the process of going out. looking for online solutions as we speak.
SOURCE: Mitsubishi wd 65733: new bulb, 1 month ago, worked
The only thing that could cause the yellow light to blink after the new lamp is that the lamp lid or access door is not placed correctly or there might be some debris between the door and the door seat to where the door sensor switch is not being activated or the switch is erratic. Try using some compressed air to clean the switch and the door seat, that might do it for you. Thanks!
