Onkyo TX-SR605 Receiver Logo
Justin Schoen Posted on Feb 22, 2013
My Onkyo TX-SR606 won't turn on
How do i get out of dock mode when no ipod dock is conected on a onkyo tx sr606
hi
Have you tried powering it off fully (holding on/off button until it switches off) then leave it for 30 seconds, and switch it on again. hope this help.
My onkyo tx-sr605 7.1 a/v tuner will not switch from game/tv to cable/sat or any other mode. I can't even get into the setup moder It won't power on even if I press the power button manually.
You have this all backwards. So essentially it won't power on. THAT must happen before setup or anything else.
http://www.retrevo.com/support/Onkyo-TX-SR605-Receivers-manual/id/2526bh742/t/2/
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Is it odd that my TX-SR606 Onkyo Receiver wont go into stand-by? It turns off but the standby light never lights.
try reset. push and hold vcr1 and then press power button while unit is on this will reset back to factory default
3answers
Hello. I have Onkyo tx-sr606 home theater
could be a bad soldered joint or loose connector, even a bad earth in the secondary power circuit.
Onscreen Menu does not appear when I push the Setup button on the ONKYO TX-SR606.
Do you have the monitor video output connected and selected on your TV?
Onkyo TX-SR606 power on default input setting and hissing sound
I had the same problem for more than a year but just lived with it. The solution is to reset the receiver to factory defaults. Page 96 of the owners manual, "turn the unit on and while holding down the VCR/DVR button, press the ON/STANDBY button. CLEAT will appear on the display and the unit will turn off". Problem solved!
No sound with the tx-sr606
This is a problem of DSP. If enter service mode,
You will see a picture like this. You can do nothing
Except selling this amp cheaply. This DSP ??????
Causes NO SOUND in all channels. Besides, never
Buy 2nd hand onkyo from 5/6/7/805 to 5/6/7/848Series amps. You will suffer the consequences!!!!
dsp problem-cul4vjmzkuvncverhuthjcbk-4-0.jpgdsp-1-uogyjvcdpkwkvogd1g1ztygl-3-2.jpgdsp1-uogyjvcdpkwkvogd1g1ztygl-3-3.jpg
1helpful
Amp turns off after about 20 mins of bluray playback
Your amp is overheating. Provide better ventilation or rig up some fans. Onkyo amplifiers are known for getting hot.
Peace.
Marco
Ipod Dock connection
The Red, green, blue from this adaptor cable
http://store.apple.com/us/product/MB128LL/B?fnode=MTY1NDA0OQ&mco=MjE4ODM1NQ
go into any of the RGB inputs on the Onkyo
The R/W go into the corresponding inputs for audio, Red and White.
One thing to note,
IF you are running one source RGB like you want to do,
you may have to monitor output the video of the amp RGB to the TV, most of these amps do not like to mix HDMI with anything else.
So If you have one HDMI going out to the TV, this solution will not work. You should look at the manual for the Onkyo regarding what paths can pass at the same time. There is usually a small disclaimer in the HDMI section.
Hope that solves your question.
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
