One possibility:
Address book data stored on the hard
disk was detected as abnormal when it
was accessed from either the
operation panel or the network.
?? Initialize the address book
data (SP5-846-050).
?? Initialize the user information
(SP5-832-006).
?? Replace the HDD.HDD defective
Secondly:
When the machine reaches the Ready condition after boot-up, the operator turns OFF the Main Power
Switch without first pressing the Operation Switch. As a result, the flash memory on the controller board is
damaged, triggering the SC.
SOLUTION:
1. Please be aware of the following:
Before turning off the machine's main power, always make sure that the Operation Switch LED is not
lit or blinking. By turning the Main Power OFF while the LED is still lit or blinking, may cause damage to
the machine's hard disk or memory.
SOURCE: Ricoh Aficio MP 4000 sc 870 error after power cord
SC870 = Address Book Data Error. This is most likely a hard drive failure especially considering the power loss. This is about a $175 repair in case you want to call around locally and get estimates to replace the drive. There is an outside chance you can get someone to walk you thru the Service Mode and do the following to reload the address book:
1. Enter the SP mode
2. 5846-50 (Initialize All Address Book)
3. Turn the machine off then on again.
Good Luck
