If you need a code for your Mercedes Benz C200 1999 radio WDB2021201A274688, you will need to contact your local Mercedes Benz dealership. They will be able to provide you with the code that you need to access the vehicle's radio.
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio. The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Mercedes service centre and get them to enter this code for you.
Hi there?
I don't know if you trying to take the radio out or just want the radio to reset so you can puch in the code. to take the radio out you'll need special tools, to reset the radio you may have to disconnect the battery and wait 5 minutes and reconnect. Good luck ...........
The radio SERIALNUMBER will be required for calculating a code
On some radios, pressing Buttons 6 and 1 or 6 and 2 (together) maydisplay a Serial Number
If not , then removethe radio from the dashboard.
Then post the radiomake+model plus all the letters+numbers on any labels,barcodes or stamped inthe metal casing.
This information canthen be used to see if a code can be calculated
you need the security code(4 digits). It should be in the black owners manual case. After you enter it press the * symbol. You can also go to the dealer and show proof of ownership and they can get it with the v.i.n. assuming it is the original radio. You can also remove the radio and give them the serial number and they can get you a code if it has been replaced. If the security code is the problem when the radio is turned on it will say code. If it shows a station number and there is no sound try replacing the fadar switch in the console that is another common failure. good luck
