I just picked up a used Risograph RZ 220. I keep getting an error message A-01-211. The highlighted problem area on the icon lights up as area 4, meaning the master roll. I keep trying to feed the master material as instructed in the manual, but the master feeder won't accept the master material. Thanks in advance for any help!
I have same error, but the release button will not work so that I can pull out the tray. Have cycled power by pulling the plug for 5 min to attempt reset, but did not work.I have same error, but the release button will not work so that I can pull out the tray. Have cycled power by pulling the plug for 5 min to attempt reset, but did not work.
You can't post conmments that contain an email address.
My Risograph RZ990 master gets wrinkles at the end of the drum.
If your Risograph RZ990 master is getting wrinkles at the end on the drum, it can be a common issue with Risograph machines that may be caused by several factors. Here are some steps to help diagnose and potentially resolve the problem: 1. Master Roll Condition: Inspect the condition of the master roll itself. Wrinkles can occur if the master roll is damaged or has uneven tension. Ensure that the roll is loaded correctly and that it is not excessively loose or tight. 2. Master Roll Alignment: Make sure the master roll is properly aligned with the machine's drum. An improper alignment can lead to wrinkles during the printing process. 3. Drum Cleaning: Check the drum for any dirt, toner residue, or debris. A dirty drum can cause irregularities in the master's transfer, leading to wrinkles. Clean the drum gently with a lint-free cloth or an appropriate cleaning solution recommended by the manufacturer. 4. Drum Condition: Examine the condition of the drum itself. If the drum is scratched, worn, or damaged, it can affect the master's transfer quality. In such cases, the drum may need to be replaced or professionally serviced. 5. Master Roll Tension: Ensure that the tension of the master roll is correctly adjusted according to the manufacturer's guidelines. Incorrect tension can lead to wrinkles in the master. 6. Master Roll Quality: Check the quality of the master roll itself. If it's old or damaged, it may not feed smoothly, resulting in wrinkles. Consider replacing the master roll with a new one. 7. Temperature and Humidity: Environmental factors such as temperature and humidity can impact the performance of the master roll and the printing process. Ensure that the operating conditions are within the recommended range specified by the manufacturer. 8. Printer Settings: Verify that the printer settings, such as speed and pressure, are correctly configured for the type of master and paper you are using. Incorrect settings can lead to issues like wrinkles. 9. Maintenance Schedule: Follow the recommended maintenance schedule for your Risograph machine. Regular cleaning and maintenance can prevent issues like wrinkles and prolong the life of the equipment. 10. Professional Service: If the issue persists despite your efforts, it may be necessary to contact a professional technician who specializes in Risograph machines. They can diagnose and repair more complex issues and ensure that your machine operates smoothly.
Addressing wrinkles in the master of a Risograph RZ990 machine often involves a combination of proper maintenance, correct settings, and occasionally replacing damaged components. It's essential to follow the manufacturer's guidelines and consider seeking professional assistance if needed to resolve the issue effectively.
our school owns a Riso EZ 200ep machines and their problem with it ; does not want to pull a master roll and give the code error A-06 and -403. Could you please help me on this.
If its CR or TR, E-01 is main motor lock. turn off machine and hold reset button in while you turn the machine on again. Make sure your master removal unit and master feed unit are closed corectly.
Remove the master that is on the drum. Then check the master roll remove it cut about 18 inches off then re install master roll. hit the reset, then print bottons.
