I had to turn the breaker off to get the ignitors to stop sparking. All burners on my Kenmore Elite starting clicking by themselves this afternoon. They all still ignite just fine, and there seems to be no other problems with the unit. But the breaker is off as the burners keep trying to light themselves now.
You probably have a shorted spark module. send model # for more help. Hope this helps!
Look inside the oven door on the side or top frame panel, or inside the drawer on the side panel. Hope this helps!
Part # 318079000, best price I found was $138 at sears. Pull the wires one by one and see if each is grounded to the cabinet with an ohmmeter. If there is a ground wire on it, do not test that one. If none or the wires are grounded, the module is bad. If a wire is grounded, replace that wire or find where it grounds and repair it. Hope this helps!
You would be correct. Remember the voltage will be intermittent and may be different as would be stated on the module. Happy fixing!
I can't find a model number anywhere!!! The best I can come up with is a placard that is riveted to the oven just behind the main door that says to call the sears 1-800 #. I've been inside underneath behind... nothing. The best I can tell you is that it's a Kenmore 40in. dual fuel range. Gas cooktop, electric (side-by-side) ovens. Thanks for your FAST help! I'll look into the spark module!
Wow, I feel dumb! Outside of the drawer, I found #790-74403-995.
I've removed the glass cooktop and I believe I found the ignition module. Is there a way to test this? Looks mint, but someone's been in there before as the cover for it was bent for previous access! Thanks again!
That's it, huh? I don't even need an ohmmeter to test it. It's immaculate in there and I can follow all the wires to the ignitors. What about wires marked "L" and "N"? (I would assume "Line" and "Neutral")? If I'm correct, as long as there's juice coming and going through these, that would prove the unit to be faulty. If this is correct, you are my new hero!
