Question about Kia Vehicle Parts & Accessories
05 kia spectra override button
Override button
    Sergeant:
  • Kia Expert
  • 403 Answers
Sometimes the wire breaks off inside the shifter remove switch and check wires or take off the center consol and check wires if not broken inside tube but if the lights on dash flashes problem from tcm causes disengaging the overdrive and making it not functional you need a scanner to find the code or remove the battery cable for 15 mins to erase all codes and see if it works if not you need scanner
Posted on Sep 06, 2014
SOURCE:
Kia sportage 05 jerking in 2nd and 3rd gear, raving the engine spontaniously, help!
SX 2.4L w/Auto Trans Slip/Jerk Shift Problem - Kia Forum
www.kia-forums.com/kia-forte...td.../55002-sx-2-4l-w-auto-trans.html
Nov 5, 2009 - 10 posts - ‎8 authors
A noticable rev in RPM between 2nd and 3rd gear only after startup. I had been ... Last edited by TeeJay1959; 11-05-2009 at 04:49 PM. TeeJay1959 is ... Started engine, accelerated out of parking lot and got a rude jerk between 2nd and 3rd gear. You are right .... 1 Attachment(s) 93-02 Kia Sportage Mud. 2nd to 3rd gear shift a "jolting" exoerience
Jan 30, 2015
Please Help with 2006 Spectra Transmission
Jan 31, 2012
2010 Surging while driving
Jul 4, 2011
2005 Kia Spectra Auto Trans Problem
Jun 18, 2005
More results from www.kia-forums.com
Kia Sportage Software Update - RepairPal
Feb 08, 2016 | Kia Cars & Trucks
2003 kia spectra starts won't shift out of park
On many newer cars there is a locking mechanism that prevents the shifter from being taken out of the PARK position if the brake is not depressed. This may be the problem. On vehicles that have this there is usually an override mechanism (usually some recessed button on the shift console) that can be pressed to release the shifter. It should be mentioned in the users manual. The image below shows the locking mechanism (16). I have read that there is a small cap on the shifter body you can remove and under it is a button you press to release the shifter. This will work until you can affect repairs.
Sep 16, 2014 | 2003 Kia Spectra
I have 05 kia rio. jump started dead battery but the cables were crossed and killed it instead. purchased new battery. car stuck in park. worked when screwdriver in override button but still won'
There is a large maxi-fuse between the battery and alternator. Its at least 100 amp or more. It may be in the cable at the battery, or in one of the fuse boxes.
You may also have damaged the key switch or the brake circuit.
You may have to get a book to get the wiring diagrams to check everything involved.
Feb 03, 2013 | 2005 Kia Rio
05 kia spectra tranny wont sepirate from the motor
First make sure you have removed all of the bolts. The ones on top are sometimes difficult to see. Instead of pulling only try twisting back and forth as you pull the transmission backwards.
Mar 30, 2011 | 2005 Kia Spectra
My car 2001 spectra kia is stuck on Parking it wont move to D. it start and everything seems fine but doesnt want to move from p
check to see if your brake lights are working .if not look for blown fuse or brake light switch or bulbs their should be a override slot or procedure to release from park.release solenoid is not working.
Jan 25, 2011 | 2001 Kia Spectra
2002 Kia Spectra stuck gear shift
Sounds like you need a new shifter assembly, or the brake switch. Most likely will be the shifter though if you can move it out of park with the override.
Sep 02, 2009 | 2005 Chrysler 300
05 kia spectra brake lights
Brake lamp switch is normally the culprit of this problem, it is located on the brake pedal assembly itself.
MIKE
Jun 01, 2009 | 2005 Kia Spectra
05 kia spectra airbag not deployed but light is on
Safety-First.
Take to dealer to investigate hidden damage to sensor, etc.
Feb 19, 2009 | 2005 Kia Spectra
Vehicle Parts & Accessories Logo
51 people viewed this question
Top Kia Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Cameron Lewis
Cameron Lewis
Level 1 Expert
Kardoc
Are you a Kia Vehicle Part and Accessory Expert? Answer questions, earn points and help others
