SOURCE: rio nitrus will not power up
I took ny Rio Nitrus apart trying to fix the screen & noticed that the rechargable battery connects to the motherboard with two flimsy little wires and a pinhead worth of solder. If you've tried everything else, it'd be worth your time to take off the back and have a look 'cuz a drop could easily have shaken one of these wires loose.
SOURCE: Transfer error - Disagreement between player and software
I had the same issue and I eventually re-formatted the player. Once I had finished that, it seemed to work again, letting me add songs.
SOURCE: Rio Nitrus MP3 Player
Ok Rio nitrus is great litle thing, and I had the same problem. This is what you should do:
1) download latest firmware for rio nitrus http://www.rioaudio.com/support/rio/downloads/Nitrus/RioNitrus_firmware_123.exe
2) unpack firmware
3) connect Rio Nitrus to your comp;
4)While holding menu buton press power button, you sholud see on display showing UPGRADER text;
5) Then upgrade the firmware ( note that this will erase all the songs- read the read me file that come with firmware);
Although I allready have the same version of firmware v.123 like the one that upgreded this solved the problemm.
SOURCE: rio nitrus
If you look in the hints and tips section for the Rio carbon there are many things I have posted that should help you. I have no hands on knowledge of the hardware of a Nitrus but I understand that it is similar to the carbon.
Hope this helps,
Mowcius
SOURCE: What driver do I need for Rio Nitrus MP3 player to
Hi, kindly get it downloaded here:
www.nodevice.com/driver/category/MP3_Player.html
Regards
