Yahoo Messenger Logo
Posted on Feb 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
81003005 Since i updated to 9 I get the above message. How can I fix this issue? It is really bumming me out, I have tried every solution on the web. I need help fast
Anonymous
Level 2:
  • Expert 61 Answers
  • Posted on Feb 16, 2009
Anonymous
Expert
Level 2:
Answers
61
Questions
0
Helped
28366
Points
114
Error code means your firewall is blocking it. It's not yahoo, it's your firewall settings on your own computer.
This is what yahoo had to say.
We released an updated version of Yahoo! Messenger 9.0 today (9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code "81003005" when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, we recommend installing this latest version.
http://messenger.yahoo.com/download/win
http://www.ymessengerblog.com/blog/Source(s):yahoo
My yahoo id is [email protected] yahoo messanger account has been blocked problem number 81003003 even mail is not opening
We released an updated version of Yahoo! Messenger 9.0 today (9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code "81003005" (Although you are getting code 81003003) when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, we recommend installing this latest version.
2helpful
Account has been blocked(81003003)
hi this is kamal This is what yahoo had to say. We released an updated version of Yahoo! Messenger 9.0 today (9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code ?81003005? when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, we recommend installing this latest version. http://messenger.yahoo.com/download/win http://www.ymessengerblog.com/blog/ best regards kamal singh
3helpful
4answers
Your account has been locked (81003003)
Account Locked error message
http://help.yahoo.com/l/us/yahoo/messenger/messenger10/messenger/mstaacctlock.html
1helpful
2answers
Messenger error 81003005
here are some causes: Firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Let's says for example, if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren?t grayed out. Click OK and login again using the new settings. If this option doesn?t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Secondly; if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code?81003005? when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful!
Thanks.
Error 81003005
I solved the problem by logging into the web yahoo messenger (http://webmessenger.yahoo.com).  Then I was able to log in with the normal messenger client.  I was having the error 81003005 on multiple computers.  After logging into the web messenger, the yahoo client worked on all my computers
13helpful
6answers
Yahoo messenger 81003005 error how do u fix it?
New 9.0 version: fix for sign-in issues February 5, 2009 on 1:32 pm | In 9.0 version | 32 Comments
emot_wink.jpgWe released an updated version of Yahoo! Messenger 9.0 today (9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code “81003005” when trying to sign in, this latest version should fix that problem. Even if you were experiencing a different kind of sign-in issue, we recommend installing this latest version.
8helpful
8answers
Errror 81003005 wont let me sign in to yahoomessneger
ok, in my case i remembered I tried using a proxy on internet explorer and forgot to put it off, so the proxy connection was still on even though the proxy was dead.
It now a proven fact to me that internet explore settings are linked to yahoo mess!
so make sure your internet explorer is working ok without proxy:
1. Open your Internet Explorer
2. Go to Tools > Internet Options then click the Connections tab
3.Click the LAN Settings button and a new dialog box will open
4. At the new dialog box, look for the Proxy server checkbox, if this is checked, uncheck it.
5. Then your done, click OK button for the dialog boxes.
6. Try logging in to your Yahoo Messenger account.
good luck =)
1helpful
Yahoo messenger 81003005 problem
To get away from errors you need to use YM8.1
Messenger "9" 1st version was in Beta (testing) form. The newest version is not, But it's not working well either. Stick to 8.1 until they work out the Bugs. Including people using 8.1 trying to message ones with 9 or reverse they are having compatibility problems; like text not showing,pictures not showing. It shuts down on Vista users , not allowing people to log in.Web cams do not always work. Many things do not work or are missing that YM 8.1 has. It Seems for Vista users it is so buggy Yahoo is giving up on it and are no longer trying to fix it. http://www.ymessengerblog.com/blog/2008/...
Download 8.1 here;
Yahoo 8.1: http://www.soft32.com/download_30.html.....
Use this method: Start,My PC, C drive, open Program files.Next open Yahoo file then Messenger file.Click on UNWISE to Un install messenger 9 completely. Do not just delete yahoo file as this can cause problems with other Yahoo programs.
Your contacts list and messages are stored online and will be there when you return to 8.1 messenger.
Another big problem is with the latest update for Flash Player
Flash player 10 Does have conflicts,and 9's latest update 9.0.124.0 Can have conflicts with Yahoo(very rarely, if you are using it with no problems keep it) and is causing some Yahoo Messenger services to not load.Use the link below for a download of Flash player #9.0.115.0 It should work as it's the latest before 9.0.124.0 . You have to remove the present flash player,add/remove programs in control panel, then download the older version.
http://www.soft32.com/download_500.html....
More help can be found here; http://www.freecreed.com/userid.html...
3 weeks ago
Source(s):
Soft 32 is showing "errors" on the link. updated links;
Download 8.1 here http://www.filehippo.com/download_yahoo_...
http://www.adobe.com/support/flashplayer...
12helpful
2answers
Please try again a little bit later (81003005)
hi,try the solution posted on this site:
http://stephenhaim.com/resources/yahoo-messenger-81003005-error
please give me a good rating if solution works for u.
Thanks for using FixYa.
Top Yahoo Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
