Question about Jabra Extreme2 Bluetooth Headset
Cant adjust volume
Adjust volume jabra replies status of the battery
  • Fred Oppous
    Fred Oppous May 30, 2016
    I just got mine and had the same problem. After messing with it for I bit I got it to work. The trick is you must have audio of some kind playing through the jabra when using the volume button. I started some music playing and then tried the button and it worked. But if it is idle you just get the battery status.
Is the rechargeable battery in the Jabra BT500 replaceable?
  • jabra headset battery swap - YouTube www.youtube.com/watch?v=MMLocSWjq8Q
    • BY THEDIECLAN2004
    • 3 MIN
    • 24K VIEWS
    • ADDED 2011-12-10
    Video embedded · jabra headset battery swap theDIEclan2004. Subscribe Subscribed Unsubscribe 15 15. Loading ... Plantronics Pro battery replacement - Duration: 9:15.
  • Jabra BT500 Bluetooth Headset - Newegg.com www.newegg.com/Product/Product.aspx?Item=N82E16826552001
    • 4/5
    • 69 REVIEWS
    Buy Jabra BT500 Bluetooth Headset with fast shipping and top-rated customer service.Once you know, you Newegg!
  • Jabra SPORT Bluetooth Battery Replacement - YouTube www.youtube.com/watch?v=Sm8cSkyTmfA
    • BY GREG PAJAK
    • 2 MIN
    • 27K VIEWS
    • ADDED 2013-09-23
    Video embedded · A quick video showing the ease of replacing the battery in the Jabra Sport bluetooth headphones. Jabra says when it it out of warranty they cannot be ...
  • Jabra BT-350 Disassembly and Repair - Instructables www.instructables.com/id/Jabra-BT-350-Disassembly-and-Repair Intro: Jabra BT-350 Disassembly and Repair. I wooted a few of these dandy devices a while back and they work great but the volume buttons are weak and the solder ...
  • Jan 26, 2016 | Jabra BT500 Wireless Headset
    Volume does not adjust, when pressing the volume button up or down, jabra bluetooth tells me the status of the battery, but won't adjust the volume up or down
    I just got mine and had the same problem. After messing with it for a bit I got it to work. The trick is you must have audio of some kind playing through the jabra when using the volume button. I started some music playing and then tried the button and it worked. But if it is idle you just get the battery status.
    Feb 23, 2013 | Jabra Extreme2 Bluetooth Headset
    How do I unmute my Jabra GN 9330? It has the red "lips" lit up at the bottom of the base.
    You have the small switch on to off the ear piece that you use to adjust the volume, this also controls the mute function, just press the little blck switch in. That should un mute it.
    Dec 13, 2012 | Jabra GN9330 Wireless Headset
    I have a problem with my Jabra BT4051. I repaired it with my cell phone, and got a successful confirmation. However, there is no sound. The phone reacts as if the connection is right, but no sound. Please...
    Check to see if volume button is not turned down It is a flat button located on the top and has a plus and minus sign on either end.Plus raises volume,minus lowers.
    Nov 18, 2010 | Jabra Bluetooth Headset with Adjustable...
    Cant connect my Jabra BCE OTE4 with my LG 8300 cell phone...help
    default PIN is 0000... be sure to turn on BT on your phone first, then power on your jabra... your phone should ask to pair to the jabra and then you enter the 0000
    Aug 21, 2010 | Jabra Bluetooth Headset with Adjustable...
    My jabra works but i cant hear ne one in the ear piece but they can hear me
    Check that the volume level is high. There might be a possibility that the headset has a mulfunction.
    You may try to bend the headset slightly to check whether the issue is related to the wires/soldering...
    Dec 08, 2009 | Jabra BT250 Consumer Headset
    My jabra vbt2050 will not go into pairing mode. I hold the on off button down for 5 seconds and the light just flashes three times then waits and flashes three times and so on. I cant get the light to stay...
    Taken from another headset fix here at fixya - worked for me w/VBT2050 Mar 09, 2009- had the same issue...but i never got any notification that something was wrong or needed to be repaired...holding the volume up and down and call answers buttons all at the same time works!! Wait til the light is on constantly...and then follow the bluetooth menu on ur phone. Awesome fix!-
    Jul 18, 2009 | Jabra Bluetooth Headset with Adjustable...
    Jabra Extreme2 Bluetooth Headset Logo
    114 people viewed this question
    Top Jabra Radio Communications Experts
    Anthony Ward
    Anthony Ward
    Bobby G
    Bobby G
    Damen Wong
    Damen Wong
    Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
