I have taken some pictures with the date on the picture. I now want to delete the date from the picture but when I do DATE SETUP - off, only the pictures taken after don't have the date, the pictures before I changed the settings kept the date .
That is correct. The date setup only affects pictures when they are taken; it will not alter pictures that have already been taken.
If you want to remove the date from a picture that already has it, you have to remove it the same way you would remove any other unwanted object from the picture.
Does that mean with photoshop or something like that? What is strange is that I do have the preview without the date on my camera !
If the date is not actually on the image then is it possible whatever program you're using to view the pictures is putting it there? It it is on the image then yes, you'll have to use PhotoShop or some other photo editor to remove it.
SOURCE: Time/Date Stamp Problem
I'm sure you have done this already, but you have make sure you press the OK button after all the fields are set. Something else, make sure the batteries are new and charged.
For printing the date/time...
After this, all pictures will print with the date, and cannot be removed.
Hope this helps, if it does, please choose FixYa!
SOURCE: delete all pictures at one time
to delete all the pictures at the same time all you have to do is to press the button that gets up you photos and then open up one of the menus and go delete pictures delete all then yes. to set the date make sure you are on the normal screen so you can see what you are going to take a picture of and then go onto the settings click date and time and you can then set the date and the time, once you have put the date and time in press ok and it is done. you can then go off the menu if needed.
