THE WASHING MACHINE STARTS TO FILL WITH WATER THEN THE ALL THE DRYER, ANTI CREASE, LIGHTS FLASH. THE DOOR REMAINS LOCKED AND THE MACHINE WILL NOT WORK. I HAVE TO TURN OF THE POWER TO THE MACHINE TO STOP THIS
PLEASE HELP
That means that the machine detected a problem at a certain point of the cycle and stopped.
If the machine stops when filling check the inlet valve and the water supply.
If it stops because ofervilling check the water level switch.
If it stops when the cycle is hot water only , then check the heating element.
If it stops when draining, then inspect drain filter, drain pump , and drain hose. You access the drain hose removing a panel at the front side of the machine.
If it stops when motor is supposed to spin faster (rinse) then it is motor control unit or motor coupler.
If it is none of the above, then it is a defective control board.
my machine sounds like its going to fill, then the reduce crease and on buttons begin to flash
