Freezer and ice maker are fine-fridge is barely cool no air flow iced up at the back of the unit where the line goes in and one section of freezer wall inside is frosted over. Thought I may have packed it too tight. Unit is unplugged to thaw out now.
SOURCE: Maytag model MSD2756GE ice maker. Water not getting to ice maker.
Why was there a need to increase the freezer temperature? Are you having temperature problems as well? If so, your ice maker has a built-in thermostat that, unless and until it is satisfied, will not cycle, thereby, making no ice. If temperature seems ok, and the buzzing is only occasional, then that buzzing is most likely the solenoid valve being energized but not passing water. This is a dual solenoid valve (one supplies the ice maker and the other supplies the dispenser) located at the bottom rear of the refrigerator.
SOURCE: Kenmore bottom freezer refrigerator warming up
Hi
There is a definetely leak in the cooling gas.
Firstly... You will need to find from where the gas has leaked. It is usually on the compressor pipes..... but not always.
Secondly you are right about the Water Valve... it needs to be changed.
Regards
Berry
SOURCE: Amana AFF2534FES freezer has frost on back wall,
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
i think you have to check to make sure that
the fan inside the freezer is cycling on.
it will be concealed of course but you should
be able to hear it. i replaced one once with
the same symptoms and that fixed fridge
portion of a 2002 or 3 whirlpool. make sure
to listen closely and not mistake it for the
stronger fan motor which operates in
conjunction with and nearby the compressor.
Testimonial: "Sir; bless you! My husband and I have spent the last 48 hours trying to figure out the problem with our whirlpool fridge...and you, my good sir, solved our problem in less than 5 sentences! So a quick trip to the parts store, $52, and your excellent advice fixed our fridge. We are so grateful for your help. Within minutes of posting our problem on line, you answered our plea and told us right away what the problem was and gave us the solution to fix this problem without our having to call for an expensive service call. Thank you, thank you, thank you. Bless you for going the extra mile to help a frustrated homeowner!"
