From the day
you start brewing until the day you get to drink, I would estimate about 3
weeks at least to brew beer. So I don't think you're going to be drinking your
own brew at your birthday next week. Here is a
breakdown of the timing for homebrewing, although they are just averages. Week 1
-Primary fermentation Week 2 -
Secondary fermentation Week 3 -
Carbonating
I like the
answer that the Brew Beer and Drink It site gives about cleaning your home
brewing equipment. It seems like it's really important to get it right or you
can mess up all of your beer.
http://brewbeeranddrinkit.com/how-to-clean-home-brew-equipment/
It's very individual. If you use more, it speeds up the fermentation process but also alters the taste. I would recommend somewhere between 15-30 balls. But you should check what the directions say (yeast balls should come with some instructions on the back). Because if it's a different make to the one I'm used to, it might be completely different quantities.
NO! Don't
put your beer in direct sunlight. The
sun will promote the growth of bacteria and this will ruin your batch of beer.
It's fine to put them somewhere warm, just not in direct sunlight. Good Luck
and have patience and you will end up with a good brew.
Sure you
can. If you want to re-use your yeast for more home brews just pour the beer
out of the bottle into a clean one and then pour the next batch on top of the
remaining yeast in the bottle. You can re-use the yeast for around 4-5 batches.
The yeast will weaken a bit with each batch and the flavor will alter slightly
but sometimes that turns out to be a good thing
On average,
a 5 gallon batch of beer will produce around 3 degrees Fahrenheit of heat
during the fermentation.
In theory
you can make a good brew from day one, but it doesn't always work out that way.
There is an unspoken rule that it takes 5-10 brews for beginners to perfect
their brew, so don't worry if it didn't feel perfect on your first attempt.
Make sure
you follow the instructions down to the finest details and don't give up on a
recipe just because one batch wasn't great. Don't be tempted to tamper with the
recipe as small adjustments can make all the difference.
Brewing your
own beer requires you to boil and make beer with a wort extract. Extract
brewing is where you use reconstituted wort to make your own beer. This method
is much quicker and requires a lot less equipment than all grain brewing, which
involves creating your own wort from the beginning.
It's a great
thing to make your own beer from scratch but it's a much more complicated and
involved process than brewing your own from wort that you purchases.
