Gold is very precious metal. If there was gold, so metal detector can easily detect It. http://steeldetector.webs.com/
Finding gold in the beach is a great hunting.I have uncovered in my time metal detecting both the dry sand and the wet/water. The other important fact about gold is it is dense & heavy. This means that when it settles in the ground it sinks to the level where it is density is the same as the ground around it. That is why gold is commonly found on bedrock and with other heavy items like lead. However, keep in mind, it is not all glitter and gold because metal detecting on the beach will produce a wide variety of junk as well.research where gold has been found before. A common misconception is assuming that just because gold has been found in any certain area, you can just turn on your metal detector and start digging up gold. https://detectorly.com/purchase-reliable-metal-detector
Gold is more valuable than silver and often comes with gem stones etc, so finding it on the beach is a great thing. But - gold has low conductivity and falls into the same range as pull-tabs and foil. So if you sift those types of items out, so that you don't' get so much junk, you could also be sifting out the good stuff.
A metal
detector is a piece of equipment that responds to metal that isn't necessarily
easy to see. They are used for all sorts of things such as; airport security,
detecting land mines, and in the construction industry.
A metal detector is a piece of equipment that responds to metal that isn't necessarily easy to see. They are used for all sorts of things such as; airport security, detecting land mines, and in the construction industry.
