Sometimes you have to call your own # and then the automated voice will tell you that you have not set up a voice mailbox yet. On other phones you will go to your message folder and there is a voice-mail option on it.
Call services
From your phone, you'll be able to access and change the settings of various call
services for your phone.Contact your mobile operator to find out about the availability of call services.
From the Home screen, press MENU and then tap Settings > Call.
Fixed Dialing Numbers Restrict outgoing calls to a fixed set of numbers. To enable this
feature, you must know your SIM card's PIN2 code.
Voicemail service Shows the current voicemail service being used.
Voicemail settings
Specify another voicemail number aside from the voice mail number on your SIM card.
Clear voicemail notification
If you have a notification of a new voicemail, you can clear the notification with this option.
TTY mode
Enable this mode to connect and use a compatible TTY device with the phone.
Hearing aids Enable HAC (Hearing Aid Compatible) to amplify in-call volume.
Phone settings
Edit the call reject message, choose whether to open the message
editor when you reject a call with a message, and choose whether to
allow automatic saving of an unknown contact number when a call
with that number ends.
Cell broadcast
Enable or disable receipt of cell broadcast messages from your service provider.
Cell broadcast settings
Configure channels and language for cell broadcast messages.
Call forwarding
Select how you want your phone to handle busy, unanswered, and
unreachable calls. You can also set the call forwarding option for all
incoming calls.
Call barring settings
Choose whether to block various categories of incoming and outgoing call.
Additional settings Enable or disable operator services such as caller ID and call waiting.
Here’s how you can read your Yahoo! Mail Plus email using Outlook 2007:
From the Tools menu, select Account Settings.
Note: If you do not see Account Settings, place your cursor over the two arrows at the bottom of the list to display more choices.
On the E-mail tab, click New. The Add New E-mail Account dialog box appears.
Select the Manually configure server settings or additional server types checkbox. Click Next. The Choose E-mail Service screen appears.
Select Internet E-mail, and click Next. The Internet E-Mail Settings screen appears.
Complete the fields as follows:
Your Name: Type your name as you’d like it to appear when you send an email message.
E-Mail Address: Type your Yahoo! Mail Plus email address (for example, [email protected]).
Account Type: Select POP3 from the pull-down menu.
Incoming mail server: Type plus.pop.mail.yahoo.com.
Outgoing mail server (SMTP): Type smtp.mail.yahoo.com.
Select the Remember Password checkbox if you don't want Outlook to prompt you for your password each time you check your mail.
Do not select the Require logon using Secure Password Authentication (SPA) checkbox.
Click More Settings. The Internet E-mail Settings dialog box appears.
Select the Outgoing Server tab:
Select the My outgoing server (SMTP) requires authentication checkbox.
Make sure that Use same settings as my incoming mail server is selected.
Click the Advanced tab:
For Incoming Server (POP3), select the This server requires an encrypted connection (SSL) checkbox. The number in the Incoming Server (POP3) field automatically changes from 110 to 995. If it doesn’t, type 995.
In the Outgoing Server (SMTP) field, type 465. Under Outgoing Server (SMTP), select the This server requires an encrypted connection (SSL) checkbox.
Next to Use the following type of encrypted connection, select SSL from the pull-down menu.
If want to keep a copy of your email messages on the Yahoo! Mail server, select the Leave a copy of messages on the server
checkbox. If you want to delete your messages from the Yahoo! Mail
server after viewing them in Outlook, leave the box unchecked.
If you want to save your Yahoo! Mail messages on both the Yahoo! Mail server and on your computer, select the Leave a copy of messages on the server
checkbox. If you want your messages to be deleted from the Yahoo!
server after Outlook has downloaded them onto your computer, leave the
box unchecked.
Note: After your messages are deleted from the server, we cannot retrieve them.
Click OK to close the Internet E-mail Settings dialog box.
Click Next to continue. The Congratulations screen appears.
Click Finish to close the Add New E-mail Account dialog box.
Click Close to close the Account Settings dialog box.
Troubleshooting tips
If you still can’t send Yahoo! Mail from Outlook 2007, you might be accessing the Internet through an ISP that is blocking the SMTP port. If this is the case, try using port 587 when sending email via Yahoo!’s SMTP server. To make this change:
From the Tools menu, select Account Settings. The Account Settings dialog box appears.
Double-click your Yahoo! Mail Plus account. The Change E-mail Account dialog box appears.
Click the Advanced tab.
In the Outgoing Server (SMTP) box, type 587.
Click Finish to close the Change E-mail Account dialog box.
If you're unable to send mails, it can be related to a problem with the configuration of Outgoing Mail Server (SMTP). Verify from your ISP your incoming and outgoing mail server.
Go to Tools> Account Settings> Email tab.
Select your Email account and then click on Change.
Double check if incoming and outgoing mail sever are entered correctly.
Click More Settings button.
Go to Advanced tab and enter 110 for Incoming Mail Server port, and then enter 25 for Outgoing Mail Server.
** you could also verify from your ISP if they uses a different port for Outgoing Mal Server.
After receiving a message with sound, push the button on the side that activates voice dialing. It sometimes takes activating it twice, but it will turn the sound back on.
What happens to the incoming calls? Check that you have not set the phone so that calls are diverted to voice mail or another number. Call your service provider and they will probably be able to send you a "service message" that will reset that.
Unlike Hotmail, Yahoo! Mail offers standard POP3 access for receiving emails incoming through your Yahoo mailbox, by using your favorite email client software. To setup your email client for working with your Yahoo account, you need to select the POP3 protocol and use the following mail server settings:
Yahoo Incoming Mail Server (POP3) - pop.mail.yahoo.com (port 110)
Yahoo Outgoing Mail Server (SMTP) - smtp.mail.yahoo.com (port 25)
To send and receive emails via your LG Prada phone you will first need to set up an email account
Send and Receive emails on your LG Prada phone by setting up an email account.
To set up a new account:
From the Start-up screen select the Main Menu icon
Select Message (Figure 1)
Scroll down and select Settings (Figure 2)
Select Email (Figure 3)
Select Accounts (Figure 4)
Select Menu icon
Select New Account (Figure 5)
You will now be required to enter some information relevant to your network provider (details of which you can find here) and existing email account:
Account Name ? For example ? Hotmail, Gmail etc (Figure 6)
Email Address ? e.g. [email protected]
Your Name ? e.g. Bob Jones
Incoming Mail Server ? Click here to find out this information (Figure 7)
User Name ? e.g. bobjones
Password ? This is will be the same as your Gmail/Hotmail password
Outgoing Mail Server ? Click here to find out this information (Figure 8)
You can also set up some Advanced Settings on your email account, to do this press the Menu icon and select Advanced Settings (Figure 9).
You can now edit the following settings if you need to do so, however, they will already be set to default settings:
Protocol Type (Figure 10)
Maximum Receive Size
Save To Server
Insert Signature (Figure 11)
Reply Email Address (Figure 12)
Incoming Port Number
Outgoing Port Number (Figure 13)
Outgoing Mail Authen (Figure 14)
Outgoing Server ID
Outgoing Server Password
Once you have completed the above, press Save the in the Email Account section activate your new email account (Figure 15). You are now ready to send and receive emails.
You can also change your Network Profile and set up a Signature via the main Email menu simply select Network Profile then the new profile and activate. To set up a Signature choose Signature, then New and write your Signature and press OK
