Could you try
(1) Temporarily stick a white strip over the sensor where it detects the media or
(2) On the length of the media or
(3) Even staple same sized white media below the black one which you can un-staple after printing.
kindly ignore if these are (s) tupid answers
Ask yourself the following:
did this start after a while or its a new printer you just installed;
have you mixed the correct toners;
have you checked the toners quantity (it may be running out);
have the toners been installed properly?
if the above doesnt help you, check your printers' manual, its very important.
I believe that there is an optical sensor just under the lid or on its hing ,sometimes it gets out of adjustment and does not sense the lid closure.Other times it is just not working at all and then you need to get it replaced,probably purchase another printer they way the printer costs have dropped.
if the problem is persists you have to replace the data cable connected to the head ( this cable goes foward and backward with the movement of the heads and sometimes it brokes ) i had the same problem and the solution is this.
hello
i add a video explaining how to install sp540v in win7
u need to install the Intercon-NetTool (that u can download from the Roland website) to allow the comunication with the plotter. its all well explained in the video. good luck
SC548: Fusing unit installation error
- Definition - [A]
The machine cannot detect the fusing unit when the front cover and right cover
are closed.
- Possible causes -· Fusing unit is not installed ·
Poor fusing unit connection
check the 2 sensors on the left hand side of the copier (as you look at
where the fuser is located). These get knocked & moved out of
postion,
this sc 548 usually happens when paper jam occurs and user does not
properly fit the fuser... also not fiitted properly due to some
foreign object in between fusing belt and the sensor...
Enter SP 5810 (SC code reset), select “Execute”, select “close”, exit SP mode then turn main power switch off and on. to enter SP mode press yellow C button press 1 0 7 on numeric keypad and then hold down the orange C button from the menu select copier SP then type in 5801 and press # selest execute then power off and back on. Your machine should now be working. Hope this helps. if this doesnt solve ur problem then try contacting ur ricoh service tech
