Question about Dewalt DW077KD T Self Leveling Rotary Laser Combo Kit With Free Tripodconsist Of DW077KD And DW0736 P...
I need to calibrate rotary laser DW073
I am laser technician, i have a DW073 out of calibration. I need instructions to calibrate. I have a colimator, and laser is off the screen.
  • bsnawder Feb 15, 2009
    INever mind, i see you have to adjust to level and adjust the vials to level.
Sounds like you figured this out on your own. I calibrate my own DW073 regularly without any fancy gadgets. I use the calibration check procedure in which the unit is placed about midway between fixed objects 100' apart.
These have a front and back and sides, so first you mark where the laser hits facing front to back at your targets. Then turn it 180 deg. relevel and resite. If the difference between the new and old marks is not the same then I turn the adjuster to halve the inconsistency and once that is accomplished, tweek the adjusting screw at the end of the level vial. (Because if you have adjusted more than the tiniest bit, the bubble will no longer display as level. So having established level, or closer to it, the adjustment here is actually to bring the relevant bubble vial back to level rather than assume they are level and adjust the physical beam mechanism (unlike the old physical sight levels where you adjusted the actual optics -- a little more like adjusting a rifle scope). Then you repeat for the side to side vial.
Anyway sounds like you are set so I posted this for anyone who happens to find this thread and is looking to field calibrate their DW073, e.g. don't have time or money to get it done in some shop.
I also wanted to post an add on question. Did you figure out how to adjust the "cone error", i.e. the accuracy of alignment of the twin lasers. They appear to have allen set screws that lock their adjustment, and maybe they are then reaimed by using a slotted screwdriver on the brass ring surrounding the laser. Maybe these are made eccentrically or slightly beveled so turning the laser reaims.
So far, my cone has stayed within the specs of 3/32" at 25' in the manual. But I'm seeing two lines at maybe 150' out. Probably that is close enough for gvmt. work, and I may find the adjusment so sensitive that I can't really get it any closer. But I'd at least be interested to know the method for adjusting the cone error.
Thanks,
Brian
Posted on May 06, 2010
  • rpaulcunning
    rpaulcunning Dec 04, 2013
    Instruments aren't typically designed for adjusting cone error. Tolerance should be less that 10 arc seconds at 100 ft. I normally replace the spidel assembly or core module if cone error gets worse than what you are seeing. You can some times adjust the prism to remove cone error on certain types of lasers. It isnt recommended or acknowledged in any service manuals I've seen.
    New Friend:
I'm a handy fix it kind of guy and would like to know how do I fix a cone error on my Spectra Precision LL500 plain laser , as I have calibrate it but have a difference of 4mm from the A axis to the B axis
Posted on Jan 23, 2011
  • rpaulcunning
    You'd have to replace the prism. (core assy). If they get a bad cone error it's usually cheaper to replace the entire unit. That is a great laser. That is one of the only things that isn't easily fixed on that unit or any unit. Cone errors are normally fixed with replacing the spindle assy or core module. There aren't many lasers that allow an adjustment for that.
6ya staff
SOURCE:
Geo fennel fl200a-n calibration
ck to see that piviot bearing does not have and dust or junk in it and moves very easy , i use mine for drywall and i have to clean out piviot all the time to get proper level from it
Jul 06, 2014 | Stanley 77 156 RL100 Manual Leveling Dual...
Instruction manual for DW073 rotary laser
Go to the Dewalt service site at http://servicenet.dewalt.com/ and search for your model in the Find Parts box. You'll be presented with several accessories that have model numbers starting with DW073. Select your model number and under downloads you'll be able to view or download the parts breakdown and instruction manual.
Jan 09, 2013 | Drills
DEWALT DW079 LASER LEVEL CALIBRATION
You can not calibrate the Laser in the field it needs to be sent to a dewalt service center however you can check the calibration to see if it is off
download the manual here with instructions on how to check it
Jan 04, 2012 | Measuring Tools & Sensors
DW079 CALIBRATION
Here is how you get your laser into adjustment modeY axis; Power and scan key at same time, unit then will tip from Y1 to Y2, then recenter. use up and down arrows to bring laser into adjustment. Let unit stabilize for 30 seconds, press scan key, you will get a continuos beep, now at same time press down arrow key. This will store your new calibration.To get X axis into adjustment mode power on and up arrow at same time, and for Z axis type laser onto Z axis and use adjustment procedure for Y axis. Saving your calibrations is the same as in Y axis. Hope this helps you
Jan 04, 2012 | Office Equipment & Supplies
Need to know how to calibrate dw077 laser
Hold down the ( V ) button while powering the unit on. THe puts the unit in cal mode for the Y axis. Hold down the up button while powering on the unit, this puts it in cal mode for the X axis. that is as far as I have gotten.
Paul
Apr 01, 2011 | Dewalt DW077KD T Self Leveling Rotary...
How do i calibrate a dw 087k laser
Here is a link for the owners manual for that particular laser. http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/593338-00,DW086.pdf
In there are the instructions for a Field Calibration Test. These units should be sent to DeWalt Factory Service for Calibration. If the unit is less than 1 year old they should calibrate it for free under their "1 Year Free Service" warranty.
Oct 09, 2010 | Dewalt Dw087k Selfleveling Line Laser...
How do I calibrate my stanley laser level
to calibrate you need to have an area 75 to 100 feet in distance. place laser on tripod 20 feet from one end, take measurements on short and long end, then move laser to center of range and take measurements on both ends . the distance between both sets of marks should be within + or - 1/4 inch if not move level screw to move beam to center then center bubble
Jun 17, 2010 | Stanley 77 156 RL100 Manual Leveling Dual...
I need to calibrate the coats 850 wheel balancer can u send me instruction on this
hi,
to calibrate coats 850, first you take a balanced wheel, tie it on machine shaft, enter the wheel dimension or wheel data such as distance, width and diameter, the press c90c, start the machine after completing cycle machine stops, add 100gm wieght out side the wheel and run it again, after this complete cycle your machine will be calibrate,
if you have any problem you can sent me email on zafakar@yahho.com
must reply me.
best regards
Zafar
bye
Jul 13, 2009 | Tools & Hardware - Others
Dewalt DW077KD T Self Leveling Rotary Laser Combo Kit  With Free Tripodconsist Of DW077KD And DW0736 P... Logo
3,682 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
john h
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
