Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
Anonymous Posted on Feb 15, 2009
E-2 Error on LX30 Hobart Dishwasher
Our Hobart dishwasher is displaying an E-2 error with a wrench. We've tried turning on and off the machine but it still gives us the same error. My husband swears there is a reset button but we're not sure where it's located. It's Sunday and a holiday weekend and we need the dishwasher NOW!
  • Anonymous Feb 18, 2009
    We spoke to someone at Hobart and they said to make sure that we cleaned the inside because something could be tripping the sensor. My husband cleaned and scrubbed and after a couple of tries of turning it off and on, cleaning again, IT WORKED! Problem solved. We never did find out if there was a reset button but I think the turning it off and on is the reset.
paultech8226
Level 2:
Scholar:
  • Expert 109 Answers
  • Posted on Aug 08, 2009
paultech8226
Expert
Level 2:
Scholar:
Answers
109
Questions
0
Helped
63556
Points
156
E-2 error is a fill problem. Water did not reach the lower probe within the time out. (innitial fill only
1- Is the bottom probe clean?
2- No fill water (check valve, hose,fill screen in end of hose, and fill source.)
3- low water pressure, should be 20 PSI flow.
4- Fuse 1FU blown.
5- Check wiring to fill valve.
6- Check relay board function.
Hobart error code f20
F20 only appears on Washing machines.
E2 error code on Hobart dishwasher E0, E2, E3 & E4 - This appears if the machine isn't filling or filling high enough. When any of these codes display, the unit won't run. Check out our troubleshooting guide for possible causes.Jul. 17, 2019
Hobart Dishwasher Error Codes ' Parts Town
I have a Hobart Dishwasher model LX30, it seems to stall when in the fill cycle from the start, which blocks any further function except shutting down, on the screen there appears a wrench insignia.
Hobart LX30H ML 104354 Manual Page 28
According to the manual ... the wrench icon comes on with OTHER codes for the LX30. Did you get a flashing P1, P2 or P3?
Or for that matter, get any associated E codes to come up?
Depending on the P or E codes there are fixes discussed on prior Fixya answers for this machine ... search there for more help
E3 Error code on hobart lx30 dishwasher.
my dishwasher Hobart LX 30 will not shut off and displays 30
6helpful
2answers
P1 error code on LX30 Hobart
This is a bad sump temperature probe. The unit will function, but will not heat nor display the wash water temperature.
This is a very easy fix. Order Hobart part number 328994 from your nearest Hobart parts dept.
Turn off and drain the unit. Kill the power to the unit at the circuit breaker. Remove the lower front cover. Locate the screw-in temperature probe at the front of the sump. Unplug the sensor from the wiring harness, remove with a 7/16" open end wrench. Screw in the new probe, using teflon tape of the threads, snuggly. It does not need to be super tight. Plug it into the harness, reinstall the front cover, turn the breaker back on, and start up the unit.
TURN THE BREAKER OFF AS EVEN WITH THE UNIT "OFF" THERE WILL BE 120 VOLTS PRESENT AT THE SUMP HEATER (yellow wires) DUE TO ONLY ONE LEG OF POWER BEING SWITCHED OFF!
4helpful
E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
3helpful
Hobart LX30 error code wrench & E5
What error code is displayed?e1,e2,e3,e4?I'm a hobart tech let me know.
Apr 10, 2009 • Dishwashers
2helpful
3answers
Hobart LX 30 P2 Error and unit overflowing!
Hi drogers77,
I'm not a Hobart technician, but here what I founded in my manual for the LX30 error message:
LX18 / LX30 display shows E0, E2, E3 or E4
1. Low water pressure - check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2. Make sure probes are clean
3. No water pressure - main water supply valves may not be working
4. Drain valve open - turn machine OFF to drain machine, then ON. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the OFF-ON procedure. If problem persists, call your local Hobart Service Office.
5. Delime machine.
Hope it will help you.
pepsicrazy
3helpful
Wrench and code p3 display
this is a probe booster error your probe failed replace it
3helpful
Hobart lx30 E3 error
Error Code E3 relates to a problem with the fill. Specifically that the water level has not been recognized at the middle water sensor. This can be caused by a problem with the drain system as you describe, or by low water pressure to the machine (should be 15-25psi flow), or bad wire connection to this middle sensor.
Check for proper water pressure first (should be a gauge on the machine) during the fill. Then check / repair drain as needed. These will probably eliminate the problem
Top Hobart Dishwashers Experts
vince
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
