Connecting your Acer laptop to your home wireless network is fairly simple. Before you begin you need to know the SSID broadcast name (Wi-Fi) network name and security passphrase (Wi-Fi network password).
Move the Wi-Fi switch to the "On" position. Not all models have this switch. Open the Windows Start menu and select "Connect To." A list of available connections will appear. Select "All" from the drop-down menu to view all available networks and connections within range. Select the desired network and click "Connect." Enter the security passphrase if prompted and click "Connect" again to join the network and gain wireless Internet access.
Wireless configuration for your laptop http://en.kioskea.net/faq/294-wi-fi-wireless-configuration-for-your-laptop - for-acer-users
SOURCE: Skype video using Acer Aspire Mini Laptop camera?
If you have a WEB camera you need to configure your video Webcam settings. Open Skype click on Tools - Options - Video Settings - select your Webcam model.
When you open Skype click on Tools - Options - Audio Settings and click on Microphone and select the microphone you are using and save the setting.
If you still have problems with your mic. then - To test if the microphone is working, go to Start - Programs - Accessories - Entertainment - Sound Recorder and record you voice. Can you see your voice recording, the green line should vary as you speek.
If you see a flat green line, then the microphone is either faulty or the wrong microphone is selected.
SOURCE: ihave an acer aspire one mini laptop with webcam
Linux or Windows version? If Windows, go to START, SETTINGS, CONTROL PANEL, SCANNERS AND CAMERAS and click on the USB Camera icon or download and run SKYPE.
SOURCE: Acer aspire 4736z: My laptop's wifi button doesn't
Same problem, mine works b4 upgrading to vista ultimate, i think its the driver ,
i tried many , get "LAN_Atheros_1.0.0.41_Vistax86x64"
try installing it , it works for me for a day cause untill vista auto updates and screw my laptop
hope it works for u , there are different driver tho
SOURCE: my laptops' unit is Acer Aspire 3935. The button
this lights blinks all the time (its searching for connection even when you are not)......your laptop is just fine
