Question about Equus 2002 Mazda Protege Obd2 Can Code Reader For Vehicles Built After 1996
2002 Mazda protege code p0117 - Equus 2002 Mazda Protege Obd2 Can Code Reader For Vehicles Built After 1996
    President:
  • 643 Answers
OK i looked this up on my mazda shop manual an this is what is says:
DTC P0117 = ECT(Engine Coolant Temperature sensor) circuit low imput
-PCM monitors ECT sensor signal at PCM terminal 38. if voltage at terminal 38 is below 0.20V,PCM determines that ECT sensor circuit has malfunction.
POSIBLE CAUSE
-ECT sensor malfunction
-Short to ground circuit between ECT sensor terminal A and PCM connector terminal 38
-ECT signal and ground circuits are shortened each other
-PCM malfunction
Posted on Feb 21, 2013
SOURCE:
What is the meaning of trouble codes 12,13 and 18 on my 2002 mazda 323 protege 1.6L ZM engine. I got these codes using a jump wire and LED light on diagnostic connector.
i dont know what codes you managed to trip but those are not proper diagnostic codes. OBDII codes will start with a letter and have four numbers (P0304, for example). these codes can be retrieved with a code reader or a scan tool.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Nov 28, 2015 | 2002 Mazda Protege
The check engine light is flashing in my 2002 mazda protege 5. what does this mean?
This means an error has been detected by your engine management system. The next step is to pull the error codes from the computer and investigate those indications.
Jul 26, 2010 | 2002 Mazda Protege
2002 Mazda Protege timing belt replaced and
Scan PCM for codes. Check that timing is correct again.These DOHC engines are easy to install a tooth out. Start from the top of engine when installing timing belt on this type of engine it's the easiest way to do it. If you took CRANKSHAFT pulley apart make sure the pick up ring behind isn't placed in backwards.
Oct 20, 2009 | 2002 Mazda Protege
Obd2 code p0300 on mazda protege 2002
Just had one of these with a maxima, the code is multiple random misfire, when a misfire occurs, to start is do the basics, replace the plugs, check fuel pressure, clean throttle body, and coolant is topped up. also I have seen if the O2 sensor is not working correctly is can cause a misfire, you will need a scan tool to look at what the O2 sensor is doing, o rby back probing the sensor (don't damage the O2 sensor wires). If it wires replace them as well, if it has coils they usually dont give that code if one fails, it will pinpoint that a certain coil if one fals.
Oct 02, 2009 | 2002 Mazda Protege
How to replace the serpentine belt of protege 5 2002, also need the routing diagram
Posted by Asker under 1997 Mazda Protege for their 2002 Mazda Protege 5.
Both are included Below
Click on the following free direct Link. It has the Belt Diagrams for the 1997 Mazda Protege with either the 1.5L DOHC In-Line 4-Cylinder or 1.8L DOHC In-Line 4-Cylinder Engines; along with various engine options (AC/No AC, etc.). Included are Instrucional Diagrams for loosening (for removal) and tightening (for replacement) using the Adjustment and Locking Bolts/Nuts.
http://www.2carpros.com/car_repair_information/year/1997/make/mazda/model/protege/1997_mazda_protege_drive_belt_routing_diagram.htm
Click on the following free direct Link. It has the Belt Diagrams for your 2002 Mazda Protege 5 2.0L DOHC In-Line 4-Cylinder Engine; along with various engine options (AC/No AC, etc.). Included are Instructional Diagrams for loosening (for removal) and tightening (for replacement) using the Adjustment and Locking Bolts/Nuts.
http://www.2carpros.com/car_repair_information/year/2002/make/mazda/model/protege5/2002_mazda_protege5_drive_belt_routing_diagram.htm
Let me know if this helped, or if you have additional information questions. Feel Free to contact me at FixYa.com!
Apr 13, 2009 | 1997 Mazda Protege
2002 Mazda Protege horn location
Their are usually in back of grille or on the underside of rails. you will need to take off the front bumper to get access.
Jan 24, 2009 | 2002 Mazda Protege
Open Questions:
See all Equus 2002 Mazda Protege Obd2 Can Code Reader For Questions
Equus 2002 Mazda Protege Obd2 Can Code Reader For Vehicles Built After 1996 Logo
154 people viewed this question
Top Equus Computers & Internet Experts
Alun Cox
Are you an Equus Computer and Internet Expert? Answer questions, earn points and help others
