We have our extensions set up when someone calls and the answering machine picks up, they can push the extension and it transfers them to the phone number assigned to the extension. how do you change these phone numbers?
Tech issues can show up often and require real thought and progression without loss of information, contact list, or budgetary data, and so forth. For taking care of tech issues, it is required to call at our tollfree number which is anything but difficult to dial and realize where you get finish help from Toshiba Tech Support Number. It really gives you the pleasantry of sitting at home or office and has the issue settled with no burden. With its sufficient arrangements, you get the preferred standpoint to expel the glitch by reaching our administrations is very straightforward and bother free 1-833-283-8333.
For more info: https://www.support-number.co/toshiba-support/
You have to obtain the voicemail users guide for administrators. This can be found at http://www.telecom.toshiba.com/ and if you have a problem a dealer may be located who can do this for you.
SOURCE: Switch unable to transfer calls to extension
check the extn number izzit the correct number
try use that phone call to displayed phone to c wat the extn number
SOURCE: Transferring call to my voicemail
DK system call forwarding in icm #604 for forward busy and no answer
SOURCE: Can I call forward only my extension on this
Yes. Pick up phone and dial *72 and follow prompt instructions.
This is what I wrote up for our inhouse manual on telephone administration for this phone:
Problem: An employee pushes the Message button to receive a message but it calls someone else's desk. This is caused by whichever extension the phone forwards to when pushing the Message light. For example: if the person at 333 pushes their blinking message light and it forwards to 316 that means that the person at 316 most likely tried to call 333, got a busy signal and accidentally pushed the Message button before hanging up thus setting 333 to call forward to their extension when they got off the phone.
All phones on our system should have this feature turned off, but if it happens this is the two step process to resolve the issue:
Solution: First, push the Message button to figure out which extension it is forwarding to. Take note of the extension and hang up. With the hand set NOT picked up, dial #409 and Release. You may have to do this multiple times to clear the call forwarding because it needs to be done for each incidence that the person accidentally set up call forward. Finally, in the management software go to Station > Station Assignments. Select the extension # that the Message button was forwarding to (the one you noted above). Under the Basic tab at #41 Active Message Waiting select Disable. Select Submit.
