Maytag Gas Range Model is MGR6772bds. Serial Number: 14578504cn
It sounds like a utensil has fallen below the heating elements.
Took out covers to heatting elements. Took off drip shield covering burners. nothing there. I did notice around range door of bottom oven, there is a metal/mesh door seal that looks and feels completely burnt (ie hard, almost browning blackish color). Not sure how seal is getting burnt as I thought they were heat proof. Haven't foudn anything out of the ordinary.
Is there any way the door has gotten bent or misalined Someone using it to set something heavy on it, Turkey, large ham ect ect
SOURCE: Maytag gas range model MGR5750ADW
hi thanks for the question the part you need is the oven sensor witch is located , in the oven top left /looks like a pen replace that part the number i got is 1365 from repair clinic . thanks the appliance doc
SOURCE: Maytag Gemini oven glass door panels impossible to clean
We had an ugly spill of hot grease/water from a roast, and lots of it ran right into the vent holes on our oven door, covering various layers of glass and other parts inside the door. Yuck. Thankfully we found this site!
"fixetheoven" was certainly on the right track, but missed a key step that makes this job much, much easier. (Maybe they had a few too many sips of wine during the process?! :-)
Anyway, the key to make the job easy, and do-able by one person, is to pull the door off the hinges before starting to remove any screws! Here's how we did it:
1. Open the door about four inches or so, it will stay in place. Hold the door at the sides and lift it up, sliding it right off of the hinges! Now lay it carefully face up on a table so you have easy access to the screws, and no danger of the glass dropping out of the bottom of the door (as apparently happened to "fixedtheoven".)
2. Remove the two screws that hold the panel on one side of the door. (One screw is halfway up the side panel, the other is on the bottom edge of the door.)
3. Slide the panel off, paying close attention to how it fits into place so you can return it to its original position later!
4. Remove the two screws that hold the panel on the other side of the door, and slide that panel out as well.
5. Remove the three screws that hold the panel across the bottom edge of the door, and remove that panel.
6. Now you can slide the front glass out from under the top edge of the door.
7. Clean the front glass, the side panels, and the bottom panel, as needed.
8. There will be another layer of glass inside the door. If it needs cleaning on the underside, remove the screws from one of the metal brackets that hold the glass in place. You can then slide this piece of glass out from the metal bracket at the other side.
9. After cleaning everything, reassemble the door by reversing the above steps.
10. Lift the door by the sides and carefully slide it back into place on the hinges. Be sure it is properly in place and being held there before you let go!!
11. Now go pour that glass of wine and sip to your heart's content, while admiring how clean your oven door is!
SOURCE: Maytag Performa Electric Range (PER1510) tripped circuit breaker.
first, un-plug unit and remove rear access cover,it could be a wire with bad insulation that has shorted to the body of the unit,could be an oven/broiler element,could be one of your feed lines to the unit shorted to ground,does it trip brkr w/o anything turned on???you can also isolate the problem that way.good luck
Hi friend, thank you for your post!
I understand that your Frigidaire dishwasher is giving off an electric burning smell and you are seeing smoke coming out of the door vent. It could possibly be an issue with your control panel or door vent, both have electrical components inside of them. Since it could be either one of these underlying issues I would recommend having a technician come out to your home and diagnose and repair the dishwasher. Hope this helps. -Matt
