Signal not strong enough to get internet service
You should just have to plug the N300 into a wall outlet, and plug an ethernet cable into the ethernet/network port. Access the N300 by typing 192.168.1.1 into your web browser's address bar to access the N300. It has been a while since I set one up, but if I recall correctly it should just ask you to choose the wireless network taht you want to repeat, select your home network and enter the password for it and save settings.
SOURCE: no internet with wireless laptop
could be that the laptop's encryption settings are wrong and it cannot perform the DHCP and thus may reverts to 169.x.x.x which is called "auto-IP"
SOURCE: wireless internet access
i was having this problem on my macbook when using WPA encryption. Switch the router to use WEP and it should be fine.
SOURCE: Lynksis Wireless Router does not stay connected to the Internet.
I suggest checking the documentation of your linksys router in the linksys site. Get the manual and that would tell you how to set it up. Regarding the router being broken, it is possible. Are you wired or wireless to the router?
SOURCE: DIFFICULTY IN THE WIRELESS ROUTER CONNECTION
1. Try to raise the height of the wireless router and or put it in a window if you need the range outside.
2. Try switching the channel that you are running on as some channels work better than others.
3.Your next step would be going with a nema enclosure (water tight box) and runing the router via power over ethernet and a power over ethernet adapter for the top side (so you can power the router via ethernet cable) and from the roof or attic you should get the range that you need. Keep in mind this will void your warranty and ethernet surge suppressor would be a good idea. Don't forget the router also needs air to keep cool or it will overheat.
4 if all that fails then the next step is going with router that will accept a pigtail(an adapter that connects a wireless card to an N type connection that most wireless antennas use) and a directional wireless antenna.
good luck.
SOURCE: I have a strong wireless signal but I can not get
Having a good wireless connection, does not mean you have an internet connection. Go into the router and click on status and see if you have an internet connection active on the router. You can click on setup in there and start again for settin g up your internet connection, you will need the username and password giving to you by your Internet Service Provider when you originally signed up with them
