Question about Marantz SR8500 Receiver
No audio I've had my Marantz SR8500 for over 3 years and have not had any problems with it.  A few months ago, I started hearing "quacking" noises from the rear speakers and subwoofer.  I now get no audio at all.  There is no audio through the headphone jack either.  The wiring is all fine.  Any suggestions?
SOURCE:
SOURCE: Marantz support question
Hi I had my SR7200 in the shop also. The 1st time they said that they couldn't find anything wrong with it. I brought it home and had the same problem. Brought it back and they had it for about 1 month and finally called and said that they talked with Marantz and the DSP needed to be replaced. They said that they would have to send it to Mararntz and it would cost about $150
Posted on Feb 28, 2008
SOURCE: Marantz SR8500
Check the settings on your dvd player!. It might be set to PCM
instead of HDMI.
Posted on Mar 10, 2008
  • 6 Answers
SOURCE: Marantz Sr8500
Check the speakers impedance. it should be greater then 6ohm otherwise you overload the system. Also, if the speaker sytem is rated (in Watts) below the amplifier's power it overloads the amp at higher volumes.
Posted on May 18, 2008
  • 121 Answers
SOURCE: Marantz SR7500 headphone jack stopped working
There is a contact inside the jack that is closed when the plug is inserted. Apparently this is no longer happening. This should be an easy repair for a qualified technician.
Posted on Feb 26, 2009
  • 4234 Answers
SOURCE: no audio output - Marantz 2238
This can be as simple as a poor connection somwhere in the voltage regulator circuit or a defective driver transistor or output transistor. In any case, this is a simple repair for any shop that works on vintage receivers. If it is the outputs, that will be the most expensive repair from a parts perspective. The outputs will cost in the $5-$10 range for each one and it could be 2-4 pieces. If you wish to attempt this repair yourself, you will need a multimeter that has a diode checker. Let me know and I'll provide additional details and instructions.
Dan
Posted on Apr 06, 2009
Difficult to start (hear noise) turn the key few times and starts
- For starting problem check the following:
- Battery (perform battery test with battery tester).
- Check battery terminals for any corrosion and sulfate deposits.
- Battery to starter motor cable.
- Battery to engine ground and chassis cable.
- Starter relay and solenoid.
- Starter motor.
- Ignition switch.
- Wiring and connectors.
- Alternator.
Mar 02, 2014 | Cars & Trucks
Our LG tv has started making a vibrating whistling sound when you first cut it on, you can hear it get faster and faster then slowly goes away.. Also over the past few months I've notices the picture
the picture getting darker means the lamp has aged and u need to replace it another thing u need ti replace the mirrors in the light tunnel of the light engine they have faded secondly the noise means the colour wheel has aged you need to replace it u will have to replace the whole light engine cos the color wheel comes inbuilt the light engine and u will be ok ontact lg dealer in your area
Jul 19, 2013 | Televison & Video
TV Rarely Starts
Check all the solder terminal at its main power regulator section circuit. Any loose solder terminal can poise this type of problem. Resolder all the suspected solder terminals by applying a little more solder. If you wish to get more details, check this site.
Apr 22, 2013 | Hitachi 32UX01S TV
A few years ago I purchased a SlumberAir Mattress system by La-Z-Boy and I love it. It is the bed I sleep in every night, but I've run into problems with the air mattress. It seems after three m
You should check the coil mattress cover. Feel around to make sure nothing is puncturing the bladder. It is not normal for them to fail like that. When you deflate it, you must make sure all of the air is out of the bladder before folding the unit back into the sofa. If you don't, you make end up with a problem at the seams.
Sep 16, 2012 | la-z-boy.com
My holmes air purifier makes a screeching sound
If you can access the fan, spray lubricant onto the shaft as close to the fan body as possible. It will work it's way into the bearing
Apr 14, 2012 | Holmes Products Air Purifiers
Error numero 2 marantz
Hello Allisonvasqu,
It's not exactly an answer, you have this problem about 5 years ago and I'm with this problem now. Could you solve your problem ? How could you solve it ? Thanks !
Dec 17, 2010 | Marantz SR-780 Receiver
Powerline interference now
Did you ask the Power Co. if they Boosted Power through these lines Recently? Is there a new Housing Addition anywhere close that would warrant a Boost in Power? This would be the Problem I think.
Jan 01, 2009 | Audio Players & Recorders
This is the problem with computerized stereo's. The old analog stuff we could fix forever, but many of these digital problems, only the maker has the tools to repair. Feel fortunate that yours will even offer you support, even though expensive.
Good luck.
Jan 28, 2008 | Marantz SR-7200 Receiver
Marantz SR8500 Receiver Logo
75 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
