Need more information.
Project is not clearly defined.
Add a comment with clear description of each wire and what Load is being controlled.
Why are you using a 4-way switch? Are you controlling 240Volt circuit?
Photoelectric switch usually has red, black, white wires, and usually replaces a single pole switch but can also be used to control 240Volt circuit in some wiring diagrams.
http://waterheatertimer.org/images/Wire-photo-eye-125.jpg4-way switch has 4 screw terminals and is generally not used to replace a single-pole photoelectric eye, but can be used to control 240Volt circuit in some wiring diagrams, so I'm not sure what you are doing.
http://waterheatertimer.org/images/Typical-3-Way-switches-450.jpgUpvote the help, and add a comment
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
