When I switch on my Electrolux Fully automatic EW757 machine, it is not starting. I had checked with all washing programs but water does not seem to be filling in the machine. I have checked the water inlet, pipes, etc. everything seems ok. When I run only the dryer program it runs fine as water is not required for that.
SOURCE: cloged inlet filter
You can also buy new filters to replace the old inlet filters from Home Depot. They are not LG brand they are "generic" filters but they do work. LG does not supply these filters the only way to get them from LG is to purchase the entire inlet valve (keep in mind you have 2 hot and cold) to obtain these filters. You can call the parts dept 888-393-6484 and get the part numbers for these valves and a distributors phone number so you can purchase the valves from them. Hope this helps.
SOURCE: Diplomat 8512 Washing machine -
This is a problem with the pressure system usually caused by a build up of powder residue but can be caused by other blockages. Remove machine lid and locate pipe which is about 6mm in diameter. follow pipe down which will lead to pressure bottle. Clean out and replace and should be ok. If bottle is clear check pipes for other blockages and check preesure pipe for damage.
SOURCE: ERROR H20 STOPS PROGRAM DUE TO LIMITED WATER...WHAT CAN I DO?
The fact that you have 240V to the valve does not prove that the valve is o/k. Determine which is the live wire, and leave connected to valve coil.
You need to remove the neutral wire from the valve, and test with your meter that as well as having 240V going in, you have 240V coming out on the other terminal, if you have not , then you have a faulty valve..Simply replace it.
I assume that you have a neutral feed to the valve, because if you have not, then the fault is probably in the pcb board.
The coils on these valves often go open circuit.
Plz rate my solution.
Thanks.
SOURCE: Washing machine is not completing it's wash cycle
either you have a blocked hose to the pump or the pump itself is either jammed or the impellor has come off the shaft. either way i think you will need to replace the pump. i presume you managed to get the water out? if so i would say the pump is favourite.
SOURCE: Hotpoint WT761 washing machine - Error code F-10
Thats strange, F10 means no cold fill.
Ok back to basics, you can check the pressure switch by taking off the tube and gently blowing into it and I mean gently, you should hear a click if its ok - make sure the other end is'nt blocked, blow it out with a cycle pump near the drum end
