The disc is probably an incompatible format for this model player. Even if the disc is finalised in your PC, or in a DVD recorder, this player may still be unable to read it. Some DVD recorder/players do not recognise DVD+R (or +R DL) media, while others won't recognise +/-RW discs (except CD-RW); this is a model limitation - not a fault with either your player, the PC burning software or the discs themselves.
Nothing can be done to fix this except purchasing a model which accepts multimedia (+R/DVD-RAM etc). The question is, does your player play ANY normal DVDs? I am guessing your player will accept DVD-R DL discs just fine since this is standard as well as proper shop-bought movies.
Test the created DVD with TMPGEnc v4.0 Xpress here is the free trial link It has a read source function that will fail if the DVDR has not been authored correctly.
If this works and scans in the full DVDR then I suggested that you buy a branded DVD+R like Philips who created the format, if this still fails I think you DVDR 3380 will need a service.
fitted a new drive in but it wont play normal dvds.
it recognises +- discs and formats them as it should
just need to work out how to make it play normal dvds.
dont want to pay for advise thanks
You have to finalize the disc. if the disc goes to the end it will finalize the disc automatically. If there is some part of the disc not used you have to do it yourself. IN DVD MODE PRESS SETUP, THEN DISC EDIT, THEN FINALIZE. FINALLY PRESS YES. That should do it.
Sounds like the DVDR is recording from the digi-box through the TV, so when the TV is switched of or into standby the signal is lost, causing the recorder to pause.
Assuming the digi-box has two scart sockets, connect as follows:
Scart 1 or TV scart of the digi-box to the TV.
Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
