Konica Minolta 26NA53040 7130 7025 7020 Oem Lower Fixing Roller Assy New Logo
Posted on Feb 20, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My printer Konica Minolta stopped working and showed me an error code F-26-6
I think it was an ink detecer problem
  • Norman Weimar
    Norman Weimar Dec 26, 2015
    Hi fathykahila, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? could not locate the F26-6 service manual what model machine????
Claude Kayser
Level 3:
Top Expert:
  • Konica Minolta Master 9,098 Answers
  • Posted on Dec 26, 2015
Claude Kayser
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5066055
Points
28436
The printer stops working & showed me an error code F-26-1
www.fixya.com/.../t16683015-printer_stops_working_amp_showed_me
Feb 20, 2013 - the printer stops working & showed me an error code F-26-1 , How can I repair it ? I think it s relating to a - Konica Minolta 26NA53040 7130 ...
Konica Minolta 26NA53040... Repair Questions - Fixya
www.fixya.com/.../p4700437-konica_minolta_26na53040_7130_7025_...
Konica Minolta 26NA53040 7130 7025 7020 Oem Lower Fixing Roller Assy New ... Theprinter stops working & showed me an error code F-26-1 , How can I ...
1 Related Answer
firecontrol7
Norman Weimar
  • 7035 Answers
  • Posted on Dec 31, 2014
SOURCE: how to reset error code 3505 in konica minolta bizhub 600
When you reinstalled the upper and lower fused rollers mite have flipped the sensor so it's not riding on the fuser roller
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica bizhub 423 red light blinking
If the red light is blinking on your Konica Bizhub 423, it usually indicates an error or issue with the printer. Here are a few things you can try to resolve the issue:
  1. Check the display panel: The display panel on the printer should show an error message or code indicating what the issue is. Check the manual or contact Konica Minolta support to find out what the error code means.
  2. Restart the printer: Try turning off the printer, unplugging it from the power source, waiting for a minute or so, and then plugging it back in and turning it on.
  3. Check the toner: If the toner is low or empty, the printer may not function properly. Check the toner levels and replace the toner cartridge if necessary.
  4. Check for paper jams: Paper jams can cause the printer to stop working. Check the printer for any stuck paper and remove it carefully.
If none of the above steps work, you may need to contact Konica Minolta support for further assistance.
Konica minolta c280 showing error codes 3423, 3334 and 2451 How can I clear the codes
2451 replace the cyan (Blue ) Image unit
3423 replace the fuser unit
3334 No such code
1helpful
My yellow imaging unit is on back order, is there anyway to still use the printer until it gets here
Basically -no. If you could get a reset chip for it, you could probably carry on using the original drum for some time. For example http://www.tonerstop.com.au/konica-minolta-bizhub-c353-bundled-set-of-4-compatible-drum-chips
Konica 7022 26-3
Yes I stated what I recommended to do in your last post!
The printer stops working & showed me an error code F-26-1 , How can I repair it ?
Remove the drum cartridge, then remove developer unit, then the charge housing above the drum the remove the drum do not touch it has to be done from the side of drum. once removed then is sensor that has a white cover on it, there is also a clear one white one is in the rear on the left side clean DO NOT USE A VACUUM Cleaner the static electricity will destroy the sensor. Then re install. run all required check . Unless you know what you are doing get a qualified Konica Minolta Technician Has to have Konica Experience You have a legacy Konica machine
Konica Minolta magicolor 2430DLshowing Fatal o8h
Error 08 relates to the main motor having problems turning. Quite often this is caused by a faulty consumable (opc,toner or transfer belt). Could also be that the lid is not closing properly and stopping the toner carousel turning freely.
Konica Minolta Copiers
F26 Toner density adjustment problem. This means machine is undertoned. To repair, replace developer and enter "47" mode. Press 51. Press print. Allow the machine to cycle until it stops. Some feel that you should disconnect the toner motor first. This ??? ?????? happens probably because either machine wasn't set up properly, or the customer kept on using the machine with the toner light on.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
